If you regularly fly your drones outdoors, you’ve probably worried about getting your pride and joy stuck in a big tree at some point. But flying indoors doesn’t guarantee you’ll be safe either, as [Scott Williamson] found out. He once got his tiny 65 mm Mobula 6HD quadcopter stuck in a roof beam at an indoor sports complex, and had to set about a daring rescue.
The first job was recon, with [Scott] sending up another drone to survey the situation. From there, he set about trying to prod the stuck quadcopter free with a improvised lance fitted to the front of a larger drone. But this ended up simply getting the larger bird stuck as well. It eventually managed to free itself, though it was damaged severely when [Scott] caught it as it fell. As told to Hackaday, [Scott] thus decided he needed to build a mock-up of the situation at home, to help him devise a rescue technique.
In the end, [Scott] settled on a grappling hook made of paperclips. A drone lofted a long length of VHS tape over the roof beam, and he then attached the grappling hook from ground level. The VHS tape was then used to reel the hook up to the rafters, and snare the drone, bringing it back down to Earth.
It took some perseverance, but [Scott] ended up rescuing his tiny drone from its lofty prison. The part we love most about this story, though, is that [Scott] planned the recovery like a heist or a cave rescue operation.
Ah! The Old Charlie Brown Predicament!
The tape is pretty neat for visibility. A fishing pole and reel with Dyneema line is very good, but not so visible.
One would think there is a way to change lights in the rafters?
I’d imagine a building that size MUST have a scissor lift to maintain the lights, skylights, electrical, etc up in the tall parts of their building. 15 minutes up and down – quadcopter rescue complete.
At the university I worked at only a trained maintenance person could operate the scissor lift. A non-emergency work order would have to be submitted. So a stuck drone wouldn’t be retrieved for days. Also someone would have to foot the bill for the maintenance person’s time. No building of that size has someone on standby to run a scissor lift to retrieve a drone unless it’s specified in an event contract and paid for.
As a licensed electrician and a project manager, most places do not own lifts and we rent them for the half day or day needed to do ceiling work.
They might just rent one for the one or two days a year they need one.
Oliver Jeffers’ “stuck” comes to mind…
https://www.goodreads.com/book/show/11211540-stuck
I think the rescue drone may have had a better chance if he’d gone in from an angle instead of perpendicular to the beam. Of course, it still would have been very difficult, since adjusting the angle of the probe requires forward/back movement. Perhaps having a downward slope would have made it easier to approach more slowly and carefully.
Finally a good use for video tape in the 21st century.
