If You Can’t See A Solar Panel, That Doesn’t Mean It’s Not There
In the shift away from fossil fuel energy sources, there has been a huge expansion in solar power. We’ve seen solar thermal plants in the desert and photovoltaic panel farms covering huge areas of land, but perhaps the most potential comes from placing the panels on rooftops. In some parts of the world this is encouraged through a system of subsidies, as is the case in Italy. But what if your building is part of a protected world heritage site such as the Roman city of Pompeii? The answer comes in the form of traditional roof tiles that hide their photovoltaic elements under a polymer skin that looks for all the world like a traditional Roman pan tile. As is so often the case with such products, the manufacturer’s description page is cagey about the details in the name of protecting their invention. What they do tell us is that the tile uses conventional solar cells mounted underneath the polymer layer, which is described as “opaque at the sight but translucent to sun rays“. This sounds like an inherent contradiction, so naturally, we’re intrigued as to how it works. Continue reading “If You Can’t See A Solar Panel, That Doesn’t Mean It’s Not There”
