ESP32-Powered Alarm Clock Gets A Comprehensive 2.0 Upgrade
[Mike Gassman] had an alarm clock, but his wife didn’t like the brightness or the sound. Thus, he set about building a more suitable replacement to fit his needs. The latest upgrade to the project is a significant one.
The Rouse Clock, as he calls it, is something we first saw a few months back in an earlier form. It’s built with the Waveshare ESP32-S3-Touch-LCD-3.5-C. It’s a horribly long part name, but it’s basically an ESP32-S3 microcontroller with a 3.5″ touchscreen LCD already stuck on the front of it. Armed with this, [Mike] already had much of the hardware he needed. Alternatively, the design also works with the Freenove FNK0104N or the CYD E32R35T. The hardware is wrapped up in a 3D-printed housing, with a nice big snooze bar on top so you can slap the clock to quiet it if you need to sleep in on a bad morning. There’s also an optional backup battery to prevent missed alarms from power outages. The general goal was to build a smart clock that worked without subscriptions, apps, or an ugly cloud service.
The clock makes excellent use of the big, bright LCD, showing the time nice and clearly. However, it’s the version 2.0 firmware that has really expanded the functionality. The same hardware now also grabs other useful data, like weather and sunset times, and displays it on the screen to tell you more about the day ahead. Taking advantage of the ESP32’s wireless connectivity, the clock can also act as an Internet radio. Indeed, it’s an internet clock radio, because you can use a stream as an alarm if you wish. It will also display photos or provide soothing sounds for sleep. Configuration is straightforward, as it’s handled through a web interface served by the ESP32 itself. You can even view the clock’s current display from the web interface if you need.
If you’re looking to build a clock quickly, or some other internet-connected appliance, it’s pretty easy to get started with these modern boards that slap an ESP32 and a screen together at the factory. We love a good clock build around these parts. That’s why we feature so many of them! Video after the break.
