Stair Climbing Rover Gets Up With Rocker Bogies
Doctor Who eventually made light of the fact that the Daleks were critically impaired when it came to staircases. This rover from [WildWillyRobots] doesn’t share that issue, thanks to a smart suspension design.
The rover itself is built using 3D printed components for everything from the enclosure, to the suspension system, as well as the wheels themselves. It uses a rocker-bogie design, which NASA designed for Mars-bound rovers and we often see copied for terrestrial applications. Gear motors are used for their plentiful torque, and they are placed directly within the wheels. Servos allow the individual wheels to be steered, allowing the rover to crab sideways and perform zero-radius turns.
The rocker-bogie setup does a great job of keeping the rover’s wheels touching the ground, even over rough terrain. It readily tackles a random pile of bricks with ease, in a way that many four-wheeled designs would struggle to match. Given its trials on Mars, it’s easy to call the rocker-bogie setup a thoroughly-proven design.
We’ve featured plenty of other rocker-bogie builds in the past; many of them are 3D printed as well.
8 thoughts on “Stair Climbing Rover Gets Up With Rocker Bogies
  1. clearly the six-wheel configuration is the most economical rocker-bogie design, but I’ve often wondered if there would be any advantages to an eight-wheeled rocker-double-bogie configuration. either way, love seeing projects like this.
    1. “scribd.com/document/408269305/Rocker-bogie” if you are a Scribd member
      “https://pdfs.semanticscholar.org/d0fc/f3164271535f7aeef2bfa399d7029e930750.pdf?_gl=1*13qdox6*_ga*NDA4Njk0NDU4LjE2NzY3NTY3Njk.*_ga_H7P4ZT52H5*MTY3Njc1Njc2OC4xLjAuMTY3Njc1Njc2OS4wLjAuMA..” formulas if you really want to break your head on it.
  2. tag it up with a link, thanks for the lighting the bulb again hackaday! “https://www.printables.com/model/194299-stair-climbing-rover”
  3. Very nice cable management!
    All the rocker bogie designs I’ve seen are symmetrical left to right. Would there be any benefit to both sides using the exact same components? This would place the two-wheel bogies at opposite corners.
