Tiny PCB PiezoPiano Plays Just One Octave
Grand pianos are beautiful instruments, but take up altogether too much space. Upright pianos are smaller, but still fairly hefty. When it comes to the PiezoPiano, though, we suspect nobody could complain about its diminutive size. It’s a tiny thing with just one buzzy little octave for your playing pleasure.
The PiezoPiano is a single PCB device with a ATmega4809 running the show. It has eight buttons and eight piezo transducers that give you just one octave’s range on the keyboard. Truth be told, that’s only in one scale; you’re not getting the whole twelve tones of flats and sharps included. And, when we say keyboard, we really mean “tactile buttons.” You get the drift. It’s all assembled in a cute enclosure mimicking the shape of a real grand piano.
Fundamentally, it’s a cute little musical desktoy that reminds us greatly of the Stylophone. Impressively, though, those eight buzzers mean it has eight-note polyphony. That’s nothing to sniff at compared to all the monophonic synths out there. It’s also available on Tindie if you’d like to buy a kit off the shelf. Video after the break.
11 thoughts on “Tiny PCB PiezoPiano Plays Just One Octave
      1. Or ask Kurzweil to determine if the 12 note chromatic scale or A:440 is really the optimum once the human brain and interconnected computing occurs after the (his) singularity.
        Both of these were arrived at empirically. Maybe there’s a new dimension of music that’s much more pleasing. šŸ˜Ž
  1. Put resonating tubes on the piezo cluster but in a row and have a mini pipe organ. Resonating at the fundamental pitch will mellow the cicada like buzzing harmonics.
  2. > those eight buzzers mean it has eight-note polyphony.
    One of the very first things I did when learning MCUs was to program a piano. It made eight different square waves out of eight digital pins, and pressing the keys would connect each output to a single piezo buzzer through a separate resistor. Eight note polyphony.
    That’s how they used to do it. You’d have a top octave generator and the rest of the circuit would just divide by two for each octave down.
    1. Does that affect the way each note is voiced? Clearly with 8 separate speakers each note will sound the same regardless, but if you’re playing them all through 1 speaker does it affect the intonation or volume if you’re playing multiple notes?
Leave a Reply to DudeCancel reply
