Tuning into a GPS satellite is nothing new. Your phone and your car probably do that multiple times a day. But [dereksgc] has been listening to GPS voice traffic. The traffic originates from COSPAS-SARSAT, which is a decades-old international cooperative of 45 nations and agencies that operates a worldwide search and rescue program. You can watch a video about it below.
Nominally, a person in trouble activates a 406 MHz beacon, and any of the 66 satellites that host COSPAS-SARSAT receivers can pick it up and relay information to the appropriate authorities. These beacons are often attached to aircraft or ships, but there are an increasing number of personal beacons used by campers, hikers, and others who might be in danger and out of reach of a cell phone. The first rescue from this system was in 1982. By 2021, 3,632 people were rescued thanks to the system.
The satellites that listen to the beacon frequencies don’t process the signals. They use a transponder that re-transmits anything it hears on a much higher downlink frequency. These transponders are always payloads on other satellites like navigation or weather satellites. But because the transponder doesn’t care what it hears, it sometimes rebroadcasts signals from things other than beacons. We were unclear if these were rogue radios or radios with spurious emissions in the translator’s input range.
The video has practical tips on how to tune in several of the satellites that carry these transponders. Might be a fun weekend project with a software-defined radio.
We’ve seen homebrew satellite devices, but none for an emergency beacon — we aren’t sure what the legal aspects of that would be. There are other satellites that unknowingly host pirate radio stations, too.
rouge => rogue?
(delete this comment at will)
Not as bad a saying nucular out loud as if the speaker is unable to pronounce the words “new” and “clear” back to back :)
Everyone does that. Everyone has said the George W. Bush version in genuine mistake, not just reference. It’s wrong, but it feels good.
Real-a-tor
I used to work on the 406 transmitter side of the COSPAS-SARAT link. All the data on the signal is publicly available and anyone can create their own user terminal at will. It’s a really great system and would be a fun weekend project to see if you could decode a real distress burst (they happen quite often, unfortunately) from all that upconverted noise.
On ships, these are called Epirb (emergency position-indicating radiobeacon). Commercial ships are required to have them, especially after the El Faro incident.
outernet is better but have not enough satellites
