Eliminating Charge-Carrier Trapping In Organic Semiconductors
a–d, Crystal structures of the 1CzTrz-F (a,b) and 3CzTrz-F (c,d) compounds, determined by XRD. a,c, Diagrams of the two dimers of both crystallographic unit cells to show the molecular packing. b,d, Spatial arrangement of the acceptor–donor contacts in the 3D crystal structure. The triazine acceptor and the carbazole donor units are coloured orange and blue, respectively. The green features in d indicate co-crystallized chloroform molecules. (Credit: Oskar Sachnik et al., 2023)
For organic semiconductors like the very common organic light-emitting diode (OLED), the issue of degradation due to contaminants that act as charge traps is a major problem. During the development of OLEDs, this was very pronounced in the difference between the different colors and the bandgap which they operated in. Due to blue OLEDs especially being sensitive to these charge traps, it still is the OLED type that degrades the quickest as contaminants like oxygen affect it the strongest. Recent research published in Nature Materials from researchers at the Max Planck Institute for Polymer Research by Oskar Sachnik and colleagues (press release) may however have found a way to shield the electron-carrying parts of organic semiconductors from such contaminants.
Current density (J)–voltage (V) characteristics of electron- and hole-only devices of 3CzTrz and TPBi. (Credit: Oskar Sachnik et al., 2023)
In current organic semiconductors TPBi is used for electron transport, whereas for this research triazine  (Trz, as electron acceptor) and carbozole (Cz, as donor) were used and compared with the properties of leading-edge TPBi. While a few other formulations in the study did not show remarkable results, one compound (3CzTrz) was found using X-ray diffraction (XRD) to have a structure as shown on the right in the heading image, with the carbozole (in blue) forming essentially channels along which electrons can move, while shielded from contaminants by the triazine.
Using this research it might be possible to create organic semiconductors in the future which are free of charge-traps, and both efficiency and longevity of this type of semiconductor (including OLEDs and perovskites) can be improved immensely.
4 thoughts on “Eliminating Charge-Carrier Trapping In Organic Semiconductors
  1. I have an OLED TV from 2017. Horrible burn-in after only about 3 years, only to get worse since.
    Has put me right off buying OLEDs in future – I feel that things are maybe a bit better today because my TV did occasional pixel refresh cycles, only to end up being MUCH worse after the cycle!
    Funnily enough you mention blue being the worse colour component, whereas on my TV, it’s red. If red content comes up, you can see the areas of burn-in, huge area in the middle of the display where red is noticeably reduced in brightness, plus a small Youtube logo top right!
    Strongly recommend to anybody don’t buy OLED until you’ve researched particular models, plus watch out for those YT channels doing long-term OLED burn-in tests. rtings I think have one on the go now.
    Pretty bad considering the brand new QD-OLED tech is looking especially bad for burn-in, within a year apparently!
Leave a Reply to StuCancel reply
