Ballistic BMW Blocks Both Bullets And Booms
Maybe you like to live dangerously. Like, James Bond dangerously. Well, we won’t judge, but we will pass this along — BMW has created the ultimate driving machine for shootouts and war zones.
Rather than having aftermarket anti-ballistic bits and bobs attached at a later date, this BMW 7 Series is born anti-ballistic and explosion-resistant, built from the ground up with armor steel. They call this the BMW Protection Core.
By building it this way, there are many advantages like more cabin space, lower curb weight, and better handling, which is exactly what you’d want if you were under these types of attacks.
For starters, the car has chunkier A-pillars and door/window frames meant to withstand the damage pictured here. The car has special armoring in the roof and undercarriage to withstand explosions. And the fuel tank is self-sealing, so you have a chance at getting out of there if the thing takes a bullet.
Can’t afford this ballistic-grade beast? You could always roll your own armored vehicle.
47 thoughts on “Ballistic BMW Blocks Both Bullets And Booms
      1. Good point, a medium sized drone with a shaped charge would cut a hole right through anything BMW have to offer. This product is at best intended to protect against civilian criminals, not warfighters.
  1. Leave it sit on a random street in Oakland, CA…. it will be like that scene in The Super where he goes out to his car and it’s just the frame sitting on blocks. He touches it and the alarm goes off….
        1. N55? Not BMW’s strongest engine for sure but generally hold out, only one I’ve seen in that was clearly maintained well had oil pump failure due to rocker arms failing. Debris then got into the oil pump as the rollers from the rocker are thin enough to fit through the strainer. Pump died and bearings spun. Engine got new rockers, pump, s55 crank, 2 replacement rods n out the door. I chalked it up as a freak occurrence. I’ve seen the n55 and 54 go through hell and , again while not the strongest engine ever, there far from weak. Imho.
      1. Cuz over here getting them fixed is a total nightmare. IF you take it into any dealer or shop expect to have it gone for months. No parts availability what so ever. Other places they are used for taxi cabs. Out here they are considered luxury vehicles. You will never see a BMW taxi cab over here.
        1. Good to know, yes here in the UK there taxis, police cars , and generally very common. Parts availability is superb and almost every city has Independent specialists. In contrast I needed parts to rebuild a 300c with MDS lifter failure and ended up having the customer have a friend bring the parts home from the states in his luggage (fortunate timing) .. now jeep dealers in the UK will get me Chrysler parts but for a while they were almost impossible to get!
        2. In many cases OEM parts actually cost less than garbage quality aftermarket parts. Maintaining a BMW in th USA isn’t so bad as long as you are able to perform maintenance yourself, and know where to get parts.
  2. Oh great! An armored vehicle that costs twice as much to fix.
    Who has more money than sense? You do, performance car enthusiast in a warzone who’s probably a corrupt oligarch!
    Let’s not pretend to whom BMW is marketing these vehicles.
  3. I used to have an old Mercedes 300SD with the W126 chassis. Both that and the W123 could be fitted with bulletproof doors and 3″ thick windows if you wanted.
    It was reasonably fast (with the 560), and the chassis could already take as much weight as a small pickup so they really didn’t have to do much to make it work.
  4. As long as the tires are not bullet proof, this is just a waste of money. Puncture even just one tire and the entire car is disabled. From there you can just access the CAN bus from the turn signal and open all the windows.
  5. That picture of the interior is such a mind hack. It shows the luxury interior and the windows being smashed but remaining in tact. That basically says β€œyou can be as cool as James Bond. Classy and chilled while cruising through explosions and gunfire”. It triggers a dopamine response where we imagine ourselves as action heros.
    The reality is that if somebody is trying to blow you up, that isn’t cool at all.
  6. Land Rover / Range Rover do a lot of this from the factory too – over the years various brakes & suspension components from the armoured + police spec variants have been popular upgrades.
Leave a Reply to dethethetCancel reply
