A High-End Studio Multiplexer Surrenders To An Arduino
The equipment used in professional radio and TV studios is both extremely high quality and very expensive indeed, and thus out of the reach of an experimenter. Happily as studios are refurbished there’s a steady supply of second-hand equipment which can be surprisingly cheap, but as [Nathan] found out with a Quartz audio router, comes with no control software. What’s to be done with what’s essentially a piece of junk? Remove its brain and replace it with one that can be controlled, of course!
On the PCB alongside a bank of switch matrices is an FPGA which does the heavy lifting. That’s “heavy” in a limited sense, because all it does is handle the chip select lines for the matrices and write data to their registers. This is a task that can be handled by a microcontroller, so in goes an Arduino Nano, which along with a few other board modifications delivers a serial-controlled studio router.
The interesting part for us in this project comes from a look at the date codes on the board, they’re from the early 2000s. This is (roughly) contemporary with the ATmega chip on the Arduino, so we’re curious as to why the designers saw fit to use an FPGA when the microcontrollers of the day were clearly up to the task for much less outlay. We suspect a touch of millennium-era price inflation, but we can’t be sure.
Meanwhile, old broadcast kit has featured here before.
17 thoughts on “A High-End Studio Multiplexer Surrenders To An Arduino
  1. Well you could add wifi and Bluetooth and extra functionality using a 32bit esp32 and a serial spi flash
    So you won’t even need a serial cable
    And can control it 100 yards away with even a smartphone
    1. why do you point out that it’s 32 bit? It gives it absolutely no benefit in this application. and why would you use an SPI flash (and presumably, the bare chip and a self made pcb) when there are modules containing both for like a dollar?
  2. You ask why the fpga not a processor .
    Looking at the desired use , this falls into a low volume board.
    The Arduino , is a great thing, but I’d say in 2000 very few if any companies would stick what is viewed as a hackers board onto their system.
    Ok they could put a processor on , but my bet is that the office was set up for either Fpga or big processor work.
    So much easier to put in a small fpga that they were set up to use.
    I was at a place , I had a great Arduino demo of the required system. A few hundred units needed. By the time it was finished , it needed a 600 MHz processor , and a pile of C++ code, and SD card.
    1. I think you may have missed the point. The Arduino series arrived in the later half of that decade, they use the Atmel processors. An Atmel microcontroller or equivalent would have definitely been a good choice for an engineer in the early half of the decade. Nothing to do with an Arduino.
Leave a Reply to AlanCancel reply
