High Caliber Engineering On A Low Torque PCB Servo Motor
Building a 3D motor printed motor is one thing, but creating a completely custom servo motor with encoder requires some significant engineering. In the video after the break [365 Robots] takes us through the build process of a closed-loop motor with a custom optical encoder.
The motor, an axial flux design, uses a stack of 0.2mm PCBs with wedge shaped coils clamped in a 3D printed body. It’s similar to some of the other PCB motors we’ve featured, but what really sets this build apart is its custom optical encoder, which was a project in its own right. The 4-bit absolute position encoder uses IR LEDs to shine through an PCB disc with concentric gray code copper encoder rings onto IR receivers. This works because FR4, the composite material used in PCBs doesn’t block IR light.
The motor’s body was printed from ABS to withstand the heat during operation. [365 Robots] didn’t skimp on the testing either, creating a 3D printed closed-loop test stand with load cell and Arduino. Like other PCB motors it produces very little torque, roughly 2% of a typical NEMA17 stepper motor. Even so, the engineering behind this project remains impressive.
6 thoughts on “High Caliber Engineering On A Low Torque PCB Servo Motor
  1. Did you recognize the mug in the picture? If you are seriously into RF than you did…. Rohde& Schwarz produced them as a giveaway, it shows all the relevant unit conversions in a ruler style. Haven’t seen them in the wild for a while.
    1. Harmonic drives have major problems due to the flexibility required of the flex spline. Maybe if you can afford to machine to high tolerances out of steel, otherwise, they are not the solution.
      Sure, people 3D print them. But how long do they last, under what forces?
      What would be really great is a motor that produces enough torque that it needs no more than about an 8:1 gear ratio.
  2. Why should such a motor be limited to tiny torque? I understand that this may not have been the goal of this project, but it is stated like it is a general fact.
    An axial flux motor’s torque is proportional to something like the 4th power of its diameter. Couple that with the ability to stack any number of them, and they can produce very high torque. Cars use them!
    I’d love to see a project that created a strong PCB motor for those people not seeking trivial torque (granted, perhaps at high RPM).
Leave a Reply to JimCancel reply
