Fire Up The 3D Printer And Build Yourself A Spiderbot
Robots are cool, so check out [Atlin Anderson]’s Spiderbot (video, embedded below) which can be made with 3D printed parts, hobby servos, and ESP32-CAM module for control and a first-person view. Looking for a new project? All of the design details are shared online if you’d like to make a hexapod of your own.
We like the effort [Atlin] put into minimizing hardware fasteners in the design of the 3D-printed parts, and aiming for a modular concept that leaves things open for expansion or modification. There’s plenty of room in the chassis for more hardware, with a convenient peg system for snap-fitting assemblies.
Control is done wirelessly via a mobile phone with an app created using the MIT App Inventor, a fantastic tool that is still going strong as a capable and accessible way to make an Android app.
As for the ESP32-CAM module that drives it all, it is a great piece of hardware with capabilities that are leveraged very nicely here. We’ve seen other projects make good use of it as well, from this 1/64 scale micro RC car to an oddball tripod camera robot.
12 thoughts on “Fire Up The 3D Printer And Build Yourself A Spiderbot
      1. Sir, your luggage must fit inside this big circle! And no weight limit. Also bring enough ammo for your P90, you never know when you need it.
  1. If you got a 3D-Printer. some technical know-how and enough money to burn on 18 Servos (the costs do add up past around five of them, especially if looking for decent ones that turn into a jittery mess). Building a Hexapod seems almost inevitable. <_<
    I fear not IF i succumb to it myself, but when…
Leave a Reply to chrisCancel reply
