A Look Inside The Geochron Clock
There are plenty of cool clocks out there, and maps by their very essence are cool, too. But a map that’s also a clock — or is it a clock that’s also a map? — has to be the coolest thing ever.
Of course we’re talking about the Geochron, a world clock that makes the relationship between the Earth and the Sun clear and has graced the offices of executives who want to impress visitors with the global nature of their importance for decades. [Attoparsec] has long coveted one of these electromechanical beauties, and when a used one popped up online for a pittance, at least compared to what they cost new, he jumped at the chance.
The Geochron he ended up with was in need of some TLC, but surprisingly little considering its mid-1980s vintage. The real treat in the video below is getting to see how these wonderful devices work. They’re basically simple slide projectors. While we here in the future would simply do everything in software on a nice flat-screen display, the base map, night-day terminators, and calendar are all contained on transparent elements that move under the power of a synchronous motor across a lighted platen. The analemma display is particularly cool; an indicator tracks the Sun’s position over the Earth with a cam that encodes the equation of time in its shape, moving through its familiar bi-lobed loop as the seasons progress.
Any clock that comes with a set of blueprints for installation purposes is alright in our book, and kudos to [Attoparsec] for landing this prize and getting it back in shape. His description of it as “the greatest clock of all time” is apt, but perhaps with a little competition. Or maybe a lot.
6 thoughts on “A Look Inside The Geochron Clock
  1. so this is how a flat earth probably looks like and works. how intriguing.
    ok. I will fetch my coat on the way out… 😊
    nice build btw
    1. Maybe they need to update/change the clock to be a half or full sphere.
      That way there is no issue with projection issues (assuming its development is kept away from the BBC weather people).
      Half sphere would mount to a wall and be viewable from one side but the mechanism would be complex since you’d have to project a moving full circle on it, although an internal laser projector could do it easily I suppose. But would it look board-roomy enough to be bought by the same clientele? You’d have the issue of it protruding a lot to have a similar size mapping since the half-sphere would be a bit large I think. A conundrum for sure.
