ESP32 Powered Crunch-E Makes Beats On The Go
There’s no shortage of devices out there for creating electronic music, but if you’re just looking to get started, the prices on things like synthesizers and drum machines could be enough to give you second thoughts on the whole idea. But if you’ve got a well stocked parts bin, there’s a good chance you’ve already got most of what you need to build your own Crunch-E.
A Crunch-E built from stacked modules
Described by creator [Roman Revzin] as a “keychain form factor music-making platform”, the Crunch-E combines an ESP32, an MAX98357 I2S audio amplifier, an array of tactile buttons, and a sprinkling of LEDs and passives. It can be built on a perfboard using off-the-shelf modules, or you can spin up a PCB if you want something a bit more professional. It sounds like there’s eventually going to be an option to purchase a pre-built Crunch-E at some point as well.
But ultimately, the hardware seems to be somewhat freeform — the implementation isn’t so important as long as you’ve got the major components and can get the provided software running on it.
The software, which [Roman] is calling CrunchOS, currently provides four tracks, ten synth instruments, and two drum machine banks. Everything can be accessed from a 4 x 4 button array, and there’s a “cheat sheet” in the documentation that shows what each key does in the default configuration. Judging by the demo video below, it’s already an impressively capable platform. But this is just the beginning. If everything goes according to plan and more folks start jamming on their own Crunch-E hardware, it’s not hard to imagine how the software side can be expanded and adapted over time.
Over the years we’ve seen plenty of homebrew projects for producing electronic music, but the low-cost, simple construction, and instant gratification nature of the Crunch-E strikes us as a particularly compelling combination. We’re eager to see where things develop from here.
8 thoughts on “ESP32 Powered Crunch-E Makes Beats On The Go
  1. Person who doesn’t understand beats or music complains about something he doesn’t understand. we’ll bring you more news at 10, with our exclusive story about old men shaking their fists at clouds…
  2. I know it has been a while since this was posted but I recently tried to build this and keep getting errors related to the is2 library pertaining i2s.philips_mode, i2s.setdatapin and I2s.write not being in scope. Is there a particular version of i2s.h needed for the CrunchOS? Any tricks? Thanks
    1. Hello, Surprisingly my friend had the same errors has you have. And when I’ve build the project it works flawlessly on my computers (windows and apple) I guess the I2S lib is in ESP32 board manager. Maybe you can install ESP32 board before
  3. Thanks Telectroboy. I was hopeful and reinstalled the IDE and all the Crunch.E libraries to see if I had something out of whack, but still get the same set of errors. I have read that the I2S library was abandoned and there is a replacement but have no idea how to remedy that.
Leave a Reply to Ed BoyCancel reply
