These days, when something electronic breaks, most folks just throw it away and get a new one. But as hackers, we prefer to find out what the actual problem is and fix it. [Bonsembiante] took that very tack when a MOTU brand audio interface wasn’t booting. As it turns out, a bit of investigative work led to a simple and viable fix.
The previous owner had tried to get the unit fixed multiple times without success. When it ended up on [Bonsembiante]’s bench, reverse engineering was the order of the day. Based around an embedded Linux system, there was lots to poke and prod at inside, it’s just that… the system wasn’t booting, wasn’t showing up over USB or Ethernet, or doing much of anything at all.
Extracting the firmware only revealed that the firmware was actually valid, so that was a dead end. However, after some work following the boot process along in Ghidra, with some external help, the problem was revealed. Something was causing the valid firmware to fail the bootloader’s checks—and with that fixed, the unit booted. You’ll have to read the article to get the full juicy story—it’s worth it!
We’ve seen [Bonsembiante’s] work here before, when they turned an old ADSL router into a functioning guitar pedal. Video after the break.
Interesting, I have a similar but simpler Focusrite Scarlet interface that also no longer mounts to USB, I wonder if it could be the same chip.
no chance: not the same beast, not the same circuit, not the same product family, and not even sure yours runs Linux.
Hunt for the common problems: dried out electrochemical caps, problems with the power supply(ies) …
Looking for obvious hardware failure is a good first step, but I like the approach of peeking into the UART interface to figure out what’s broken and when you’re looking at a >$1000 piece of equipment it might be worth spending a few hours on that.
However going as far as reverse engineering the bootloader is probably too complex for most hw engineers to do in just a few hours, so I don’t think I’d advise this approach to anyone…
If you enjoyed this video you will really like whole FeedbackLoop YT channel https://www.youtube.com/@feedback-loop/videos Tons of professional sound gear repair videos. Mackie , Shure, Harman Kardon, M-Audio, Alesis, Behringer, PreSonus, Studiologic, Kawai, Roland …
Great recommendation, thank you :-)
Wondering if he said: I have the powerrrrrr! after he fixed it :)
Does a microphone with an audio interface such as Babyface require a preamp with TLM 103 or 107 and why?
If only they could make Antelope Audio interfaces work without the need to activate them online :/
