The TimeChi Never Shipped, But You Can Build One From Scratch
What do you do when a crowdfunded product you really liked gets cancelled? Naturally, you take the idea and build your own version of it. That’s what [Salim Benbouziyane] did when the TimeChi project on Kickstarter saw its launch cut short. This device allows you to set a ‘no distractions’ timer, during which notifications on one’s phone and elsewhere are disabled, making it something similar to those Pomodoro timers. What this dial also is supposed to do is integrate with home automation to set up clear ‘focus’ periods while the timer runs.
A quick prototype of the newly minted Focus Dial project was set up using an ESP32 and other off-the-shelf components. The firmware has to run the timer, toggle off notifications on iOS and trigger firewall traffic rules to block a batch of social media addresses. Automating this with iOS was the hardest part, as Apple doesn’t make such automation features easy at all, ultimately requiring a Bluetooth audio board just to make iOS happy.
After this prototyping phase, the enclosure and assembly with the modules were drawn up in Autodesk Fusion 360 before the plastic parts were printed with a resin printer. The end result looks about as good as the Kickstarter one did, but with a few changes, because as [Salim] notes, if you are going to DIY such a failed crowdfunding project, why not make it work better for you?
6 thoughts on “The TimeChi Never Shipped, But You Can Build One From Scratch
      1. I definitely achieve a similar effect putting my phone on “silent” for focusing
        Potentially, I imagine this device might have more of a phycological impact, like a trigger for meditation or a specific state of mind.. etc
        Seems to have good benefits as a focus tool for some either way
          1. Same here, i definitely see such a device having value for people like me. The integration with HA is golden, it makes it possible to start the right music (or sounds for that matter) to help staying concentrated for the task.
            The build is superb, but when the stuff is on github it also presents to opportunity to make a different/simple version yourself; In essence it’s a very simple device.
Leave a Reply to ThoriumBRCancel reply
