Antique-Style GPS Looks Like Steampunky Fun
These days, turn-by-turn GPS navigation isn’t considered special anymore. It’s in every smartphone and most cheap rental cars, and thus everybody expects you to figure out where you’re going. If you want a simpler and less robust navigation experience, you might like to try the rather fancy RadioScout.
The RadioScout is a build from [hardlyhumanfx]—a group of engineers and artists that collaborate on fun and whimsical projects. It looks like some kind of steampunk compass, and it kind of is—but at heart, it’s powered by GPS.
You program the RadioScout using the buttons on the front panel and a rotary phone dial to enter the latitude and longitude of your destination. It then uses an internal GPS receiver to compare that with your current location, and calculates a direct bearing to where you want to go. This bearing is displayed with a large compass-like needle run by a stepper motor, and you you can use it to guide yourself onwards.
It’s an attractive build that uses lots of neat parts. The team interfaced a microcontroller with a GPS receiver, a rotary dial, and 7-segment LEDs for the latitude and longitude display. The very real bell is neat, too. The whole thing is wrapped up in a brass and wooden case that would make you a star at just about any sci-fi convention. The build video is a little vague on the finer details, but experienced makers will be able to figure out how it all works.
You can actually buy a RadioScout if it’s something you must have, but one suspects the Hackaday set would probably prefer the homebrew route.
@hardlyhumanfx
#steampunk gps i designed and built. this is just a rough prototype
♬ original sound – HardlyHumanFX
@hardlyhumanfx
as promised, a field test of the antique working GPS system I built! Available to buy now on our website HardlyHumanFX.com #steampunk #fallout #vintage
Thanks to [Charles] for the tip!
14 thoughts on “Antique-Style GPS Looks Like Steampunky Fun
  1. The problem with this kind of things, they only looks good if you have one of them in your stylish apartment, but you only can build them if you have the experience and personality of someone who build many of them. And many of them look like garbage. :-D
    1. An overdrive is a common addition to the Model T (for those not wedded to keeping them factory-original, with wooden wheels and all) — Then they can keep up with “highway” speeds (50 mph)
      1. The 2 speed Ruxstell axle was a big deal for those who built (stripped down to) a Torpedo. Shaved heads, downdraft carburetors, I don’t remember what else. They could get that stock 18 to 20hp up to 23? 25? The sky’s the limit!
        By the way, Clara Bow learns to drive a Torpedo in “Wings”.
  2. Thank you so, so much Lewin. People honestly never really notice my work and for some reason, my RadioScout really caught everyone’s attention. Funny enough, it’s the ridiculous video about using the RadioScout to find a bagel shop that went viral. Thank you again. Been a big fan of Hackaday for a long time. It’s an honor to be mentioned.
Leave a Reply to Egghead LarsenCancel reply
