Keebin’ With Kristina: The One With The Keyboard Configurator
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Have you ever wished you could experiment with different layouts super easily, just by adding or removing a few switches here and there and printing a new case? Well, [heyisjambo] says that it’s more than possible with menura, the modular keyboard system.
A collage of menura keyboards, which are modular via the VIK standard.
So many lovely options! Image by [heyisjambo] via GitHub
[heyisjambo] is happy with 36 keys, but is reduced-count-curious and wanted a way to explore without a lot of wasted time and PCBs.
At the same time, [heyisjambo] wanted to experiment with split vs. uni-body construction, and especially the different shapes that are possible when tweaking the angle and distance between them.
And as if that weren’t enough, there’s support for [Sadek Baroudi]’s VIK standard for interfacing data between PCBs, which calls for an FPC 12-pin, 0.5 mm pitch connector and allows for ultra-cool magnetic connectors. This way, you can easily add things like displays, trackpads, and trackballs in the between the halves.
Thanks for the tip, [calculus]!
Cosmos Keyboard Configurator Is Out of This World
Well, this is probably the coolest thing I’ve seen this week. Cosmos is an utterly customizable keyboard configurator by [Lost Pistachio] that uses a scan of your hand to figure out what thumb clusters, curvature, and layout are right for you, without wasting time and plastic on physical prototypes.  You should go check it out, especially to see the cool and noodly finger animations in the demo.
A scanned hand dances on the right half of a completely customized keyboard.
Image by [LostPistachio] via Cosmos Keyboard Configurator
At the top left you’ll find Basic, Advanced, and Expert modes, where Expert is playing directly with the code. You can mess with the thumb cluster keys by moving them around directly with the mouse. You want a trackball? Boom, trackball.
Did I mention that it does all this in the browser? Oh, except for a couple of things things, which are accessible with a PRO account. This costs a measly $10 and is good for a lifetime, yours or theirs.
Yes, there are a lot of settings, but it’s easy enough to get started with the docs page, which outlines some recommendations for everything from the layout to the microcontroller.
Thanks for the tip, [Timothée]!
The Centerfold: The Hacktrick
A mechanical keyboard with Selectric key tops!
Image by [tschibo00] via reddit
No, this isn’t some sci-fi prop. It’s real, and it’s spectacular. This is [tschibo00]’s Hacktrick — a gasket-mounted keyboard that uses converted key tops from an IBM Selectric I typewriter. The golf ball type element is not just for looks — it’s mounted on a special adapter and acts as encoder to scroll up/down, left/right, and push down.
The switches are mounted sideways in order to accept the keycaps without an adapter. Since the Selectric key tops are normally mounted on levers and wider in the north-south direction, the switches must be rotated, and a cross-slit Dremeled into the underside of each beautiful, double-shot key top. This way, they can still be used on a Selectric. In case you’re wondering, that case was resin-printed by a board house, although [tschibo00] sanded, painted, and clear-coated it many times.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: the Bennett/Junior
Introduced in 1907, the Junior was Charles Almon Bennett’s first typewriter. It had no paper table and utilized ink rollers. Evidently, it had numerous issues with alignment. But one thing is certain; this was truly a pocket-sized typewriter.
The Bennett Junior typewriter of the early 1900s, which would fit in your coat pocket.
Image by [Lucas Dul] via The Mechanical Type
These issues were all addressed with Bennett’s second machine, which he named after himself. The Bennett had a paper table, ribbon spools, and no alignment issues. Even so, it was difficult to type on.
First off, the keys are way too close together, which is just bad for typing in general, plus it made the wrists begin to ache after a while.
And you see how they overlap? Pressing one depresses the keys beneath it as well — hit Q, and A and Z go down with it. But hey, at least it’s ortholinear, eh? And plus, look where the Space bar is.
These things are small: just 11″ x 5″ x 2″ and a mere 4.5 pounds. They have the honor of being the smallest typewriters ever manufactured with full keyboards. If you want to take a deeper dive into one of these machines, be sure to check out [Lucas Dul]’s exploration of a Junior. You may remember [Lucas] from a previous Keebin’.
There’s Nothing Wooden About This Design
Look, I don’t happen to have any experience clacking on a wooden keyboard, although I welcome it with open arms. And unless I get some serious skills and/or cash, it’s probably going to be a while.
The Alice 60 keyboard, stunning in wood.
Image via Yanko Design
That said, the folks at Yanko Design got their hands on an Alice60 made (almost) completely out of wood, and rave about the sound, the tactility, the whole nine.
We know what plastic sound and feels like. But even the nicest plastics get slick over time with finger oils. I’m not saying that will magically go away with a wooden keyboard, only that one can imagine the oils seasoning the wood rather that ruining it.
This offering from Epomaker x Feker is currently available for pre-order for a cool $549. Not bad for something so lovely, which will undoubtedly provide a keyboarding experience like none other.
This is certainly not the first wooden keyboard we’ve seen, and it’s not even the first commercial offering. If you’re not into ergonomics and have the means to spend twice as much, check out this wooden rectangle from Hacoa. If you want to make one yourself, take a look at [Bo Yao]’s carpenter tau number, or [Steve M. Potter]’s Scrabble tile affair.
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
11 thoughts on “Keebin’ With Kristina: The One With The Keyboard Configurator
  1. Have you ever wished you could experiment with different layouts super easily, just by adding or removing a few switches here and there and printing a new case?
    No. My daily driver is a $15 A4Tech PS/2 keyboard I bought in 2005 when I was a teenager. Still works fine.
    It’s as simple as not drinking or eating anything in the same room where computer equipment is being used; and also washing your hands after eating and before using keyboard or mouse. I was crying many times when I was a kid and my father caught me eating pizza or sweets in front of screen and then beat me with his leather belt. But now I understand why he did it – this way he taught me respect to electronics and to preserve it without spending money needlesly on latest hype fueled by marketinguesqe buzzwords.
    1. It sounds more like you have learned to fear even the appearance of not being obsessively protective of computer equipment. It’s not normal for a full grown adult to have to go search for a room without any electronics before they can take a sip from a bottle of water. And it still won’t help when the reason it’s no longer usable is that its switches have begun to fail from age, or once your computer no longer supports ps/2.
      Of course you must disagree that your behavior is irrationally cautious. If so, I would be interested how you behave about cars. After all, a car has much more invested in it than a piece of computer equipment. So if you’re proportionately protective, then I’m sure the car is only driven gently and only in good weather after a full inspection of all fluids and such, and that you clean it thoroughly after every outing with filtered water and then dry it with a microfiber cloth before putting it away in the HEPA filtered garage.
      Or in other words, perhaps we don’t need to start throwing stones just because we have different preferences about keyboards?
      1. Before you start criticizing me acting all high and mighty, I never learned to drive a car or bicycle because I suffer from brain injury and epilepsy. Public transport for me is enough to go from work to home and back. I guess I am just used to simple life without wasting natural resources like many of people around the world.
        1. And if some of those coworkers have a conversation about experimenting with different flavors of coffee at a particular cafe, do you jump in to shame them for wasting paper on a cup? I’m no saint, but you’re belittling anyone who has an interest in exploring their options for keyboard layouts without having to replace the entire keyboard. Further you’re positioning yourself as better than anyone who doesn’t meet your high standards in one category, even though it seems impossible that you could have found a situation where your waste is universally less than one keyboard per two decades.
  2. Glad the dinosaur is working out for you. But your argument is not just orthogonal to the premise, it’s entirely missing the point.
    I’ve got a keyboard from 1986 that’s still going strong too, but I still experiment with alternate input devices, even though I’m twice your age.
  3. Nice article; I see the bennett came up again; I have been looking off and on at those because of the uniqueness of it. And thinking about wooden keyboards, which aren’t generally my thing… it’d be far too expensive and perhaps a waste of the limited supply of such wood, but imagine bog oak – that dark iron shine, but yet wooden, and a bit heavy.
  4. The golf ball type element is not just for looks..
    The golf ball is actually the IBM Selectric typewriter ball
    awesome level of detail in that build.
Leave a Reply to spaceminionsCancel reply
