Pictures From A High Altitude Balloon
How do you get images downlinked from 30 km up? Hams might guess SSTV — slow scan TV — and that’s the approach [desafloinventor] took. If you haven’t seen it before (no pun intended), SSTV is a way to send images over radio at a low frame rate. Usually, you get about 30 seconds to 2 minutes per frame.
The setup uses regular, cheap walkie-talkies for the radio portion on a band that doesn’t require a license. The ESP32-CAM provides the processing and image acquisition. Normally, you don’t think of these radios as having a lot of range, but if the transmitter is high, the range will be very good. The project steals the board out of the radio to save weight. You only fly the PC board, not the entire radio.
If you are familiar with SSTV, the ESP-32 code encodes the image using Martin 1. This color format was developed by a ham named [Martin] (G3OQD). A 320×256 image takes nearly two minutes to send. The balloon system sends every 10 minutes, so that’s not a problem.
Of course, this technique will work anywhere you want to send images over a communication medium. Hams use these SSTV formats even on noisy shortwave frequencies, so the protocols are robust.
Hams used SSTV to trade memes way before the Internet. Need to receive SSTV? No problem.
14 thoughts on “Pictures From A High Altitude Balloon
  1. Violates the regs:
    § 95.533 Prohibited FRS uses.
    FRS units must not be used for one-way communications other than those listed in § 95.531(b). Initial transmissions to establish two-way communications and data transmissions listed in § 95.531(a) are not considered to be one-way communications for the purposes of this section.
      1. We can always reprogram the radio for use in a US amateur radio band.
        Problem solved, licensing is as easy as a simple test and filling out a form.
        Nice project; another great use for a thorw-away radio.
    1. While you can legally transmit wi-fi over 30km (at least in many countries, check your local regs), it requires a much more directional antenna and is more sensitive to interference than SSTV. Since you can’t control where the balloon goes once you release it, and high altitude winds can be quite strong, maintaining this link is potentially a lot trickier, and the hardware to do it much heavier.
      That’s not to say it’s impossible – my understanding is that google’s “project loon” at one point used off-the-shelf ubiquiti wifi radios in their stratospheric balloons – but I wouldn’t say it’s obviously “better”.
  2. What would be the practicalities involved in increasing the data rate by say 10x or 100fold? Would it still work, but only in environments with less ambient radio noise than this system is capable of overcoming?
Leave a Reply to JouniCancel reply
