One Book To Boot Them All
Mockup of a printed copy of the Little OS Book
Somewhere in the universe, there’s a place that lists every x86 operating system from scratch. Not just some bootloaders, or just a kernel stub, but documentation to build a fully functional, interrupt-handling, multitasking-capable OS. [Erik Helin and Adam Renberg] did just that by documenting every step in The Little Book About OS Development.
This is not your typical dry academic textbook. It’s a hands-on, step-by-step guide aimed at hackers, tinkerers, and developers who want to demystify kernel programming. The book walks you through setting up your environment, bootstrapping your OS, handling interrupts, implementing virtual memory, and even tackling system calls and multitasking. It provides just enough detail to get you started but leaves room for exploration – because, let’s be honest, half the fun is in figuring things out yourself.
Completeness and structure are two things that make this book stand out. Other OS dev guides may give you snippets and leave you to assemble the puzzle yourself. This book documents the entire process, including common pitfalls. If you’ve ever been lost in the weeds of segmentation, paging, or serial I/O, this is the map you need. You can read it online or fetch it as a single 75-page long PDF.
Mockup photo source: Matthieu Dixte
19 thoughts on “One Book To Boot Them All
    1. Sadly they too only touch that other CPU architectures might exist, would have loved more in-depth articles about developing an OS on retro platforms, they might be easier to handle for the bedroom coder.
      Some old C64 or, if you want to go even older, a PDP-8 a mere person can understand, the IA-32/AMD64 platform you need to have studied and even then they are not for the faint of heart.
  1. Other OS dev guides may give you snippets and leave you to assemble the puzzle yourself.
    And if you actually follow, you’ll gain a deep understanding of what the book is trying to teach you.
    And like with any other crap by O’Reilly you’ll learn bugger all.
        1. This has nothing to do with good or bad. Like it or not, PCs selling today are using EFI, and if you are not aware of it, your new OS will not get a chance to boot (unless you enable CSM).
Leave a Reply to Stephen KellerCancel reply
