Forget Propellers, Embrace Tentacle-based Locomotion
Underwater robots face many challenges, not least of which is how to move around. ZodiAq is a prototype underwater soft robot (link is to research paper) that takes an unusual approach to this problem: multiple flexible appendages. The result is a pretty unconventional-looking device that can not only get around effectively, but can do so without disturbing marine life.
ZodiAq sports a soft flexible appendage from each of its twelve faces, but they aren’t articulated like you might think. Despite this, the device can crawl and swim.
With movement inspired by bacterial flagella, ZodiAq moves in an unusual but highly controllable way.
Each soft appendage is connected to a motor, which rotates the attached appendage. This low-frequency but high-torque rotation, combined with the fact that each appendage has a 45° bend to it, has each acting as a rotor. Rotation of the appendages acts on the surrounding fluid, generating thrust. When used together in the right way, these appendages allow the unit to move in a perfectly controllable manner.
This locomotion method is directly inspired by the swimming gait of bacterial flagella, which the paper mentions are regarded as the only example of a biological “wheel”.
How fast can it go? The prototype covers a distance of two body lengths every fifteen seconds. True, it’s no speed demon compared to a propeller, but it doesn’t disturb marine life or environments as it moves around. This method of movement has a lot going for it. It’s adaptable and doesn’t use all twelve appendages at once; so there’s redundancy built in. If some get damaged or go missing, it can still move, just slower.
ZodiAq‘s design strikes us as a very accessible concept, should any aspiring marine robot hackers wish to give it a shot. We’ve seen other highly innovative and beautiful underwater designs as well, like body-length undulating fins and articulated soft arms.
We do notice that since it lacks a “front” — it might be a challenge to decide how to mount something like a camera. If you have any ideas, share them in the comments.
25 thoughts on “Forget Propellers, Embrace Tentacle-based Locomotion
      1. Thank you very much for that link.
        It confirms my suspicion. Movement is very slow, even in the 3x sped up video.
        I guess that energy efficiency is also low, with all that water getting pushed around in all the wrong directions. But still, it’s “different”, maybe it will find some useful application some day…
  1. They are using an “acoustic modem” to communicate to the drone (?). That’s pretty cool, I had never heard of an acoustic modem before, but it kinda makes sense in underwater applications.
    Also its a lot less complex than I expected, the 12 legs are actually rigid and rotate to induce motion. Still I love it
    1. One major issue with using accoustic POTS modem underwater is how sound vibrations don’t dissipate like they do in air. Over time those vibrations tend to cause plastic to delaminate and fail – this is what caused Oceangate submarine to explode. (And why Cameron used subs connected by a long cable.)
      1. “this is what caused Oceangate submarine to explode.” False.
        “And why Cameron used subs connected by a long cable.” Also false.
        Cables are used to increase the bandwidth of connections to the sub, and make them easier to locate should something go wrong. Note, an underwater acoustic modem has a baud rate of around 250 to 5000bps (basically enough for texting, slowly).
  2. This is way cool
    If this works in water, with some modification it can work in air too.
    Small nit to pick, I don’t think this is a “research paper” by my arbitrary definition- it doesn’t appear to be in a peer reviewed journal. I’d call it a whitepaper or something else.
    The linked article itself references video S5 of the supplements, which is supposed to show it working. This doesn’t exist as far as I can tell.
    Cool stuff thanks.
      1. Well now! It is indeed a research paper so I got myself down to the Uni and looked at the videos.
        They look exactly as one would imagine- that little robot gets flailing all over and indeed gets places. It’s amusing but if anyone is thinking you missed out- not so much. Imagine a really inefficient propeller. Still cool and still darn novel.
  3. some of the robo stuff was already making me twitchy enough to start considering what sort of ordinance to carry, but now I have to learn up on spear guns
    then again maybe just gearing up s long wave magnetic pulse gun, and setting it off, continiously is a better idea
    robo drone sleepy time…..
    1. Current battery tech does not allow for any armor on robots (unless they are ICE like those weapons platforms on treads)
      Hit a hydraulic line, motor, battery, cable etc and you will disable it. Probably anything over 22lr will drop a Boston dynamics bot
      Imo if you’re set for 2 legged critters you’re good for any robots rn
Leave a Reply to Rog FantherCancel reply
