Making A Variable Speed Disc Sander From An Old Hard Drive
Our hacker converts an old hard disk drive into a disc sander.
This short video from [ProShorts 101] shows us how to build a variable speed disc sander from not much more than an old hard drive.
We feel that as far as hacks go this one ticks all the boxes. It is clever, useful, and minimal yet comprehensive; it even has a speed control! Certainly this hack uses something in a way other than it was intended to be used.
Take this ingenuity and add an old hard drive from your junkbox, sandpaper, some glue, some wire, a battery pack, a motor driver, a power socket and a potentiometer, drill a few holes, glue a few pieces, and voilà! A disc sander! Of course the coat of paint was simply icing on the cake.
The little brother of this hack was done by the same hacker on a smaller hard drive and without the speed control, so check that out too.
One thing that took our interest while watching these videos is what tool the hacker used to cut sandpaper. Here we witnessed the use of both wire cutters and a craft knife. Perhaps when you’re cutting sandpaper you just have to accept that the process will wear out the sharp edge on your tool, regardless of which tool you use. If you have a hot tip for the best tool for the job when it comes to cutting sandpaper please let us know in the comments! (Also, did anyone catch what type of glue was used?)
If you’re interested in a sander but need something with a smaller form factor check out how to make a sander from a toothbrush!
60 thoughts on “Making A Variable Speed Disc Sander From An Old Hard Drive
  1. I cut up sandpaper with wrecked scissors, like the pair that someone apparently tried to cut wire with or the pair I dropped and bent the tip of one scis so I ground them down like kids’ safety scissors. There always seem to be awful scissors around for free. But a utility knife seems at least as good because it’s so easy to swap the blade when it’s finally ruined.
    Fold and tear along a sharp edge also works pretty well with the paper-backed coarse stuff.
    1. On my bench I have wrecked wire cutters and wrecked tweezers. I mark them as such by taping some green and gold electrical tape on the handle. When I find myself with the need to cut sandpaper I guess I will add wrecked scissors to the list! :)
    1. I tried it a long time ago and it was pretty useless, but I just used the original motor driver. This one uses an RC ESC, so maybe it will produce a bit more torque. It’s still a tiny motor though.
    2. I have one with 400 grit sandpaper and a small ESC. It’s ok for sharpening drillbits and similar small blades, but I wouldn’t use it for the chisel (?) that appears in the image. I added a lid that keeps most of the dust inside, making it a nice tabletop sharpener that avoids making a mess.
  2. I “cut” sandpaper by creasing it on my drill press table edge, paper-side on the table, then just tearing it. Perfect straight ‘cut’, and no abrasive touches anything.
    1. Good idea! Of course in this case we need circular cut outs which makes things a bit tricky. If it was me I would probably use a craft knife and cut from the back paper side… I think this is one of those problems where every solution has some sort of drawback…
    1. My preference is to use hot glue for this.
      To replace the sand paper, you just heat the whole disk and then peel of the old, add some more glue and put on a new sheet of sandpaper.
      This works best if the disks are removable and you have a few of them. You can then replace the paper on two disks, and clamp them to each other to make sure the paper stays glued flat to the surface.
      I do have some real doubts about using an old HDD for this though. The motor does not have enough power for most of the sanding jobs. Maybe it’s enough for tiny works such as parts for scale model building. But I would not even attempt grinding an axe with this myself.
      1. Having read it, it doesn’t seem likely that grinding 1 ten thousandth of an inch off a lathe tool, once in a blue moon, would be a huge risk. But respirators are available.
        Doing it 40 hours a week, sure. Wear a respirator and use dust control equipment.
        1. Did you note the part about 1% of the population being hyper sensitive to carbide/cobalt lung issues and there being no test available to see if you are one of them?
          The incredibly slow painful nature of the death you (or your associates) get if you roll 00 and fail your saving throw?
          At least the dust is heavy.
          Your call.
  3. I generally just fold, crease and tear to get straight “cuts”. If I actually have to cut it I’ll score the paper backing. Once the paper backing is scored it tears off pretty easily.
  4. Hmmmm…I’ve recently become interested in gem cutting and have been eyeing some lapidary tools, but I may just order some diamond paste and see about repurposing one of my old hard drives to see if it would be a viable alternative. I am curious as to whether the torque output on a 3.5” HDD would be sufficient. I’ll also have to figure out how to waterproof it.
      1. I usually use a cheap-as snap knife, preferably one that’s nearing snapping time and cut gently from the paper side. Usually cuts enough that it makes perforations enough to easily pop out or tear the line without completely destroying the cutting edge
        1. That’s a popular myth. Cutting sandpaper won’t make your dull scissors sharp. It’ll just remove some of the roughness and actually dull the cutting edge. It’ll cut better than it did before the sandpaper trick, but it’ll get worse each time.
          Look up how to properly sharpen scissors with a whetstone. It isn’t all that hard – if you can sharpen a knife you can sharpen scissors.
      1. No, not really. You can remove the dings and rolled edge on the cutting edge that way, but that isn’t “sharpening.” It is still dull, it just doesn’t snag as badly.
        Sharpening scissors isn’t that hard, but cutting sandpaper won’t do it.
        I sharpen household scissors and garden shears using diamond “whetstones.” There’s a world of difference between sharpened scissors and ones that have been “sharpened” by cutting sandpaper (or aluminum foil.)
  5. I made one of these a while ago, just using the original hard drive board. Turns out old ~40gb HDDs just start to spin as soon as you give them 5 and 12v on the molex. (Some don’t restart spinning after a stall though).
    I just put a 5v regulator on the side and now I can just supply 12v to it.
    I really want to hook it up to something and check its SMART stats, lol. I’ve been grinding stuff for years now. I was not expecting it to last this long.
    1. I shot all my old 5 1/4 drives (the one’s that start with simple power).
      Some of them had netmare 2 on them, shot all of them to be sure.
      Powered up and spinning, some with the cover off.
      Was fun.
      Made mess.
      You realize a HF angle grinder costs $20?
      1. Really sending mixed messages here, and definitely not displaying the financial judgement that you think. I can honestly say that I don’t think shooting HDDs is more constructive, or interesting, than hacking them for entertainment.
        1. I have no shortage of old hard drives.
          Am kind of packrat.
          But these had NETMARE on them (at least some), I had to shoot them.
          I was going to expend the ammo anyhow.
          Pretty much the only loud noise I get to make since old enough for adult court. (Cars don’t count, not loud enough.)
          5.25 HDs, way before the current price of ammo.
          I remember 7.62×39 at $0.30/round…good times.
  6. Ha keep it classy sport! Obviously you are sufficiently uneducated to be unaware that the Argument ad Hominem is a classic fallacy of the intellectually stunted. Obviously you qualify!
  7. skipped through the video to answer my question: he drives the motor using what looks like a brushless speed controller from an rc airplane.
    i like the shape of this tool, with the recessed grinding surface. a little less scary than like putting your angle grinder in a bench vice :)
    i am sure there are a ton of uses for this sort of tool but i am skeptical of using it specifically for sharping like chisels and stuff because the outside is moving so much faster than the inside. seems like it will tend to grind your things at an angle?
    1. You could grind tangentially to the hub. You could even get fancy and rig up a grinding rest, that lets you set an angle for the grind and also lets you adjust the contact point closer or farther away from the hub, with motor speed adjusted so that the speed at the contact point is always the same.
  8. A very economical and precise way to cut sandpaper is with an exacto knife. I’ve been cutting get this way for years 60 grit to 2000 it works on all grits. Cutting from the paper side score it but not all the way through. This mostly saves your blade and also just bending the Sandpaper will make it break clean. Always use a razor sharp blade, but never cut through it.
  9. I’m lazy. I cut circular sandpaper by pressing a hole saw to the back of it, the paper side, to perforated the sandpaper, then tear it slowly. This produces a fair circle every time. I imagine a 3 inch hole saw would work nicely for this.
    I like the velcro idea but that would leave the sandpaper lumpy. Perhaps cut and glue 1/16 thick steel disk to the back of sandpaper and velcro that to the platter? You can clamp the 1/16” sheet metal to a wood block and use the same 3” hole saw to create the metal disk. Be sure to clamp in a minimum 3 places.
  10. If you plan on using the HDD after this and it’s old enough (pre-mid-1980s) don’t forget to park the HDD heads before sanding anything. You wouldn’t want to have a head crash, especially onto sandpaper, as that would destroy them. You will also want to thoroughly clean the platter after removing the sandpaper as the heads would also likely crash if they bump into anything remaining on it. Archive org has a collection of HDD utilities for MS/IBM DOS that includes “hd_park” or refer to your OS manual as most have a similar executable. A TSR like TimePark might also be useful.
Leave a Reply to Egghead LarsenCancel reply
