ASUS GPU Uses Gyroscope To Warn For Sagging Cards
It’s not really an understatement to say that over the years videocards (GPUs) — much like CPU coolers — have become rather chonky. Unfortunately, the PCIe slots they plug into were never designed with multi-kilogram cards in mind. All this extra weight is of course happily affected by gravity.
The dialog in Asus' GPU Tweak software that shows the degrees of sag for your GPU. (Credit: Asus)
The problem has gotten to the point that the ASUS ROG Astral RTX 5090 card added a Bosch Sensortec BMI323 inertial measurement unit (IMU) to provide an accelerometer and angular rate (gyroscope) measurements, as reported by [Uniko’s Hardware] (in Chinese, see English [Videocardz] article).
There are so-called anti-sag brackets that provide structural support to the top of the GPU where it isn’t normally secured. But since this card weighs in at over 6 pounds (3 kilograms) for the air cooled model, it appears the bracket wasn’t enough, and active monitoring was necessary.
The software allows you to set a sag angle at which you receive a notification, which would presumably either allow you to turn off the system and readjust the GPU, or be forewarned when it is about to rip itself loose from the PCIe slot and crash to the bottom of the case.
51 thoughts on “ASUS GPU Uses Gyroscope To Warn For Sagging Cards
  1. Bonkers that we have gotten to the stage that sensor makes any sense at all, though that is a great way to differentiate your product and could well become the default wanted by anybody that still LAN parties and system integrators that have to ship these monsters pre-built…
  2. Shouldn’t this be “ASUS GPU Uses Accelerometer To Warn For Sagging Cards”? By measuring the static acceleration due to gravity, you can find out the angle the device is tilted at with respect to the earth. A gyroscope measures angular velocity (rate of rotation).
    1. Looking up the chip it’s a 6DOF IMU. That said you are right that using the gyroscope for any of this seems silly. Except to maybe filter out “alert someone just smacked the case”
      1. You made me realise this won’t work without a ton of filtering, or maybe just user input? like the GPU can be mounted multiple ways. Rightly said it could be knocked. Like it needs a ton of validation to make sure it has started sagging, and the sag is going to be over weeks as well, so a log too that it can analyse.
        1. You would also need an accelerometer on the motherboard, because if the motherboard or the case is slightly tilted then the graphics card will tilt too. It should be a relative measurement.
          Filtering can simply be saving the averaged value on closing the PC (or every hour) and every few months checking if there is a downward trend in the angle.
  3. I would call it a design flaw if the card, in its standard-conforming mount of the slot(s) and PCI interface, can’t support its own weight in a vertical case. Especially since that’s pretty much the default configuration nowadays. Some case manufacturers have attempted to implement a support structure, but it’s hard to design for when the card lengths are effectively random. Not to mention damaging the PCI socket or even the motherboard substrate itself.
    1. It’s really not that hard to design for because there are defined, standard form factors for PCI-E cards so case manufacturers can build products to suit and provide the support rails for cards to slide into.
      Obviously if card manufacturers don’t build cards to the standard “full length” dimensions then it really shouldn’t be too much to ask that they design and supply a bracket that bridges the difference so your super expensive GPU isn’t flexing the BGA chips off the board?
    2. IBM Microchannel was designed with a support structure made in cast alloy, and Microchannel board were made with a blue plastic stub that slid in the support structure. Shorter board had a longer stub.
      Even the original IBM AT PC had support slots for supporting the longer ISA expansion boards.
      1. Pretty much every name brand PC I’ve ever encountered (and I have seen a LOT, I’ve been ‘doing IT’ for near 40 years now) has had those support slots, all the way from original IBM PC to the current 2024 HP Z Workstation and the 2023 Optiplex under my desk.
        The RTX5000 in the Z Workstation has a decent bracket to engage with those support slots too.
        This only seems to be an issue with aftermarket cases and cost cutting GPU manufacturers.
    3. those standards were meant for single slot cards without a heat sink. gpu cooling requirements keep demanding bigger heat sinks. but i think we got to the point where the mounting system is no longer adequate. both ends need to be supported by the chassis.
      vanity slots kind of solve the problem in a way, provided you need to use a riser cable. i really dont like those, mostly because they are meant to show off your gpu but at least its not supporting it on the shortest axis.
      horizontally mounting the card directly to the mobo tray (below the mobo) with tapped holes and standoffs might be a good idea. tapped holes and standoffs are easier to add to a case standards than double brackets or rails. cases usually have more screw holes than you can use and adding a few more and a few extra standoffs to the parts baggie is possibly the easiest solution for case manufacturers. probibly more difficult on the gpu side as the fans would get in the way. i figure the pci connection can be either a u-bracket or riser cable. later on you might mobos design their pcie slots specifically for this arrangement. it also clears the board so you can get to your m.2 drives without taking out the gpu.
      the design of some of the 50xx cards the pcie slot is on a daughter board anyway, and so theoretically you can put it in any orientation you want. still waiting for an sff build with a monoblock combined mobo+cpu+gpu cooler with the boards hanging off the block rather than the other way around.
      1. At this point I can’t think of any super urgent reason to not just flip a tower case on its side.
        Maybe stick some feet to the side-that-is-to-be-underside.
        I mean we don’t use optical drives anymore most of the time, so what is there to stop us?
        And even if you have spinning disk internal HD storage, those can be used vertical too AFAIK, or if need be you can just use a bracket to install them rotated.
        I’m not 100% sure about PSU’s though, do they mind in term of airflow if they are rotated you think?
        Not that you can’t bodge there too. a long time ago I had space (and money) issues and I cut a square out of the top of my too-small case, made some screw holes, and mounted the PSU on top and fed the wires inside through the hole. Sure it might have looked daft to some, but I had it out of sight anyway.
        And I did a similar thing once where I mounted a fan on the outside instead of inside to create room. It was clear fan with LED lighting and it didn’t look too bad actually.
        1. But then nobody can see your triple bay led fans and screens in your cpu and light up ribbon cables and the RTX5090 label.
          Since we have so many people in our house using our PC right
    1. Got a certified “chode” on our hands. This GPU either needs to go on a diet or they should just throw in the towel and start making them take up 2 PCIe slots for purely structural reasons
  4. They’d be using the accelerometer not the gyro of the imu to measure the angle of the card with respect to gravity. The gyro is only good for quick relative changes in angle.
  5. Time to flip form factors:
    Put the GPU on the ATX board and add the CPU via PCIe-slot…
    Or better yet, make two ATX boards, one for CPU and one for GPU, that can be joined edge-to-edge. Much more space for giant heatsink towers then.
  6. Back in the day, we had hard drives on cards, and the way this was solved there was a couple small pieces of channel aluminum that ran the full length of the card. How have we gotten to the point where we choose to detect mechanical failure rather than prevent it with reinforcement?
    1. Well maybe this card hit a critical point in the “mass vs. additional support” graph where adding support isn’t feasible anymore because the additional weight would require even more support which adds more weight ….
    2. Hanging an accelerometer off SMBUS and paying a few grand NRE for the software is far cheaper than machining a new support structure. That doesn’t make it the right solution, but margins even on high end GPUs are razor thin for the manufacturers and most consumers will end up buying on performance and completely ignoring reliability fixes. Note how many people still bought 4090s even though their new DC in connector design was known to spontaneously combust.
      To be fair, what hard cards had in mechanical stabilization they lost out on in reliability and utility. They were a niche solution for a problem that all but disappeared as soon as 3.5″ IDE hit the market, which was only a couple of years after their release.
    3. Indeed, my first HD was a Plus Hardcard XL 105 and had lots of black aluminium everywhere to support the drive.
      Only got rid of it a few years ago, didn’t have a machine with an ISA slot to put it in.
      1. seems such an expensive piece of hardware would warrant some structural considerations.
        in my case the gpu rests on some self adhesive rubber bumpers trimmed down for best fitment, stuck to the corners of my lower case fans. but its an sff case so i can do that. the fan mounts are like an inch below the card, and with some slim fans and bumpers it provides a good rest point. my case came with a bracket to support gpu but it was that or the extra case fans. ultimately i like my solution. most larger cases its suspended in the middle.
  7. If I remember correctly, even my Quadro FX 4600 came with a metal support bracket at the front side. It would slide in one of those plastic rails at the front of my computer case while inserting the card.
    This same bracket was also present on some big SCSI adapters and other cards that would reach to almost the front of the case. Probably something server and workstation related.
    I’m not sure if there are still any computer cases with these brackets, but wouldn’t it make sense to re-use something proven, that has been used for years? It was a really simple solution with the only downside that sometimes the HDD cage would be blocking the front of the case.
  8. really a comic problem from my perspective…easy for me to laugh at, because i don’t play modern high-end videogames or run LLMs at home. pretty sure doom3 runs decently well on “Intel UHD” integrated GPU right?
    but the mechanical problem reminds me of the old full-length ISA cards. there’s a little plastic slot in the very front of the case, which will grip the end of the card if you have one that long. i had exactly one card that was that long…i think it was pre-hercules MDA board? you know, 80×25 text with about 4kB of memory. monochrome green or orange monitor.
    i’m glad to be completely ignorant of how that has evolved in the modern era. personally, just installing a modern pcie or M.2 card is a voyage of discovery each time. x1 vs x16, M/B-keying, is this M2 slot even mini-PCIe or something else? who knows. everything’s easier away from the bleeding edge
    1. m.2 drives have been a total game changer imho. would rather mount them on a pcie card than directly to mobo, but im an sff guy so dont really have that option. pains me to see full atx boards with most of the real estate going to m.2 heatsinks. at that point put 2-4 on a card and be done with it. considering going back to micro-atx (or flex-atx, or mini-dtx) just so my drives are easy to get to.
      of course im a little biased because ive hated sata for years for its tendency to randomly stop working once the connectors and cables are a couple years old. fixing it usually requires wiggling the cable or cleaning contacts, but the fact that it happens so frequently was bugging the hell out of me. so i jumped on m.2 way before nvme was a thing.
  9. I dont think I have noticed slots in the front of cases for a while now unless its some workstation / server setup
    even 20 years ago they were blocked off by hard drive cages going from top to bottom, and todays gamer cases have to cram in a 360 x40 rad and thick ass fans and all that tubing :)
  10. I wonder why GPU makers don’t implement telescoping rails that project out from the end of the card, which can be attached to a bracket that uses screws or 3M’s heavy-duty double-sided mounting tape to attach to the side of the case. Sure, there may be fans or other obstacles in the way, but you can just sell optional brackets to work around them. Or provide files for users to 3D print them themselves.
  11. definately a hack.
    i think its about time the atx standard gets ammended to come up with a proper structural mounting methods for gpus that weigh more than a cat. 2-3 screws and an armored slot do not a mounting system make. you need a 4-point mounting system for something that big. at least have brackets at both ends. direct to chassis cpu cooler mounting would also be a good idea given the size of some of the better air coolers.
  12. This wouldn’t be a problem if we all still stood our systems with motherboards horizontal, like we used to do when the PC hardware was designed 20+ years ago. The add on card can be as weighty as you like, because you have gravity holding them in the slots and no need for all this extra tech nonsense. Funnily enough airflow would be better too, warm air rising straight up so less fans as well.
    ‘Servers’ with card cages also solve this problem neatly so maybe its time for a PC mechanical hardware re-design no we have had the original IBM PC XT hardware design for over 25 years?
    We really do pay extra for aesthetic design choices sometimes
  13. the PCIe standard actually specifies a rear bracket to prevent this from happening, but nobody seems to implement it. actually, apple used to on the old powerpc mac pros.
  14. Something that hefty should really just come with a ribbon cable PCIe extension so you can move it elsewhere. You’d think those would affect such rapid signalling but they really don’t cause any bottleneck until you’ve done something silly, like string eleven of them together in a chain and wrap them around your power supply.
  15. No one needs this though. It just adds another layer to break down and create false errors to make useable computers unusable. I hope this fails miserably and every sycophant that pushed it is blacklisted from the industry. It is yet another eventual security nightmare I would guess too. It is bad enough already thanks.
  16. Lol!
    You know how I solved it? I got a horizontal case. Now the mobo is parallel with the desktop and the GPU sits upright, no sag, no stress. It also doesn’t hang the PSU, and it doubles as a monitor stand and gets great airflow.
    So many overly complex solutions are invented for this, all we have to do is stop using fish tanks with vertical motherboards
Leave a Reply to I Alone Possess The TruthCancel reply
