Moon Phase Flip Clock Is Fantastic
A woman in a ball cap and black tank top holds a black and white image of the Moon printed on black acrylic. It can fold and is mounted on a black plastic mechanism with turning knobs affixed to the ends. There are out-of-focus shelves in the background with various items and books on them.
We love clocks, but we especially love unusual timepieces that aren’t just about showing the hour of the day. [Simone Giertz] built a flip clock moon phase tracker for a friend.
While in Egypt for Cairo Maker Faire, [Giertz] and [dina Amin] found some old flip clocks at a flea market and had to have them. [Amin] mentioned wanting to make a moon phase tracker with one, and [Giertz] decided to try her hand at making her own version. A side quest in more comfortable flying is included with the price of admission, but the real focus is the process of figuring out how to replicate the flip clocks original mechanism in a different size and shape.
[Giertz] cut out 30 semi-circle flaps from polystyrene and then affixed vinyl cut-outs to the flaps. The instructions for the assembly suggest that this might not be the best way to do it, and that printing stickers to affix to the flaps might work better since the cut vinyl turned out pretty fiddly. We really like the part where she built a grid jig to determine the optimal placement of the beams to keep the flaps in the right position after a disheartening amount of difficulties doing it in a more manual way. Her approach of letting it rest for twenty minutes before coming back to it is something you might find helpful in your own projects.
Best of all, if you want to build your own, the files are available for the flip moon station on the Yetch website. You’ll have to come up with your own method to drive it though as that isn’t in the files from what we saw.
15 thoughts on “Moon Phase Flip Clock Is Fantastic
  1. I like the idea and great that she put design files for download.
    Unfortunately, this is not a clock, but “just” the display. Having it sit on the shelf and look nice – okay. But is will show the wrong phase of the moon most of the days. This is rather distracting than helpful.
    It should flip daily automatically, sync with the local moon. An indication would be helpful to know if and when the moon is up or not. Maybe a black ring that goes around, with a white dot on it? Just rotate it, with horizon being the middle? Visually “up or down” and being able to distinguish “soon to be up” vs “not up fit quite some time”
    1. I thought this too, but I think it’d be cool to keep it super minimal. The phase of the moon is the same everywhere and not affected by daylight savings, so once you dial it to the current phase, a simple quartz clock could keep it correct for decades, even if you moved house.
      1. Right!
        At first I thought… Oh – you need to look up moon phases and current time and visibility at current location. So – internet, esp32, stepper motor for the flip display, finding the flip display zero reference. That sounds complex.
        But certainly, once set, the thing could run just on a quartz or mains frequency! Just like the clock they took apart, it just needs to advance periodically. This should work for both the phase of the moon (worldwide) and “is it up” location dependent. Just re-set it if you move far.
        Could you re-use the existing mechanism? Just add new gear ratios? Clickspring micro gear manufacturing?
        Or like a some quartz clock running off a battery?
        This could still be a microcontroller, just counting seconds and advancing a micro-motor now and then?
        I haven’t ent seen anyone build a quartz clock mechanism yet.
  2. I’ve been noodling over a moon phase display for a while. This is one of those “Why didn’t I think of this?” moments. This one is in the build queue. Thanks Simone.
  3. It don’t look right with all those fringe effects. With a vertical axis it’d have less of that, but how to move the flaps without gravity. Perhaps a little tilt with loose flaps? Make the moon smaller so it don’t show around the edges the way it is? Numbers on clocks leave black around the edge so the previous panel don’t show.
Leave a Reply to Tony MCancel reply
