BhangmeterV2 Answers The Question “Has A Nuke Gone Off?”
You might think that a nuclear explosion is not something you need a detector for, but clearly not everyone agrees. [Bigcrimping] has not only built one, the BhangmeterV2, but he has its output publicly posted at hasanukegoneoff.com, in case you can’t go through your day without checking if someone has nuked Wiltshire.
The Bhangmeter is based on an off-the-shelf “nuclear event detector”, the HSN-1000L by Power Device Corporation.
The HSN 1000 Nuclear Event Detector at the heart of the build. We didn’t know this thing existed, never mind that it was still available.
Interfacing to the HSN-1000L is very easy: you give it power, and it gives you a pin that stays HIGH unless it detects the characteristic gamma ray pulse of a nuclear event. The gamma ray pulse occurs at the beginning of a “nuclear event” precedes the EMP by some microseconds, and the blast wave by perhaps many seconds, so the HSN-1000 series seems be aimed at triggering an automatic shutdown that might help preserve electronics in the event of a nuclear exchange.
[Bigcrimping] has wired the HSN-1000L to a Raspberry Pi Pico 2 W to create the BhangmeterV2. In the event of a nuclear explosion, it will log the time the nuclear event detector’s pin goes low, and the JSON log is pushed to the cloud, hopefully to a remote server that won’t be vaporized or bricked-by-EMP along with the BhangmeterV2. Since it is only detecting the gamma ray pulse, the BhangmeterV2 is only sensitive to nuclear events within line-of-sight, which is really not where you want to be relative to a nuclear event. Perhaps V3 will include other detection methods– maybe even a 3D-printed neutrino detector?
If you survive the blast this project is designed to detect, you might need a radiation detector to deal with the fallout. For identifying exactly what radionuclide contamination is present, you might want a gamma-ray spectrometer.
It’s a sad comment on the modern world that this hack feels both cold-war vintage and relevant again today. Thanks to [Tom] for the tip; if you have any projects you want to share, we’d love to hear from you whether they’d help us survive nuclear war or not.
44 thoughts on “BhangmeterV2 Answers The Question “Has A Nuke Gone Off?”
  1. Mock testing is good, but when you’re testing for Disaster Recovery purposes it really is worth while running the best test you can do.
    Now, where do you get a small nuke…
    1. Now, where do you get a small nuke…
      The Best Korea – where Supreme Leader compensates for his erectile inadequacy with massive transporter erector launchers flaunting equally massive phallic-shaped rockets. They are supposed to be fitted with small nukes.
    1. I thought I had one once, but it turned out that the crazy-haired guy I sourced it from had given me a case full of used pinball machine parts instead. Tried to remonstrate with him in the Twin Pines shopping mall parking lot a few nights later, and, well…
        1. “You, at the back of the classroom! Is that a thermonuclear device you’re hiding under your desk? Well, mister, I hope you brought enough for everyone…” 😂
          1. THERMOnuclear?
            No.
            This is not a hydrogen bomb.
            Inner voice…’don’t ask about cobalt bombs…don’t ask…’
            Snarky inner voice…’I do have enough for EVERYONE.’
  2. HSN-1000 series seems be aimed at triggering an automatic shutdown that might help preserve electronics in the event of a nuclear exchange
    That’s exactly what it’s used for. Keeps the aircraft flying so the crew can drop the bomb before they die.
    1. The idea that there was enough demand for a “nuclear event detector” that someone actually tooled up to make commercial chips…… is not a comforting thought.
  3. Ok, so my only question is where did they get a radiation hardened raspberry pi Pico 2 W. Or is it protected with graded-Z shielding. Or is it inside a large lead, I was going to say box or chest but it would probably need to be a, building to attenuate the intensity enough to keep on working. The SoC is made with a 28 nm process, for some reason I suspect that a 6502 with fewer transistors and made with a 8000 nm process may survive more intense radiation for longer.
    1. I would put the detector on a small pole and the pico in a hole in the ground.
      Would the signal be fast enough to reach the pico though? Oh wait it’s a pico W so wireless? Would the WiFi stack be fast enough to process and send though? I don’t think so, so you really need the pico in a protected place and let the detector be sacrificed.
      But from the mention of ‘line-of-sight’ this thing sounds like it would be directional right? So you need a circle of them to look around, and of course for an airburst maybe one looking up, especially since the nukes designed to cause an EMP are detonated in the air AFAIK.
      And if you got a circle of them you can also tell people from what direction the doom came.
  4. This is an interesting gizmo.. Seems like if it detects something that would be of zero use to biologicals. If it is set off, you are done. But as they mentioned, it might detect something just barely soon enough to shunt some power and protect something from EMP. I’d love to learn more about how that works. I can build a Faraday cage and I know that nuke-hardened electronics are made, but I would love to learn specifics.
    However I am still on team nothing ever happens; this is all for academic interest only
  5. it gives you a pin that stays HIGH unless it detects the characteristic gamma ray pulse of a nuclear event.
    Curious what exactly this signal is called….
    Doomsday*?
    Not_dead_yet?
    Maybe just “nBang!”
  6. Detection threshold is 10^5 rads/s. So, a LD50 dose in an eyeblink, a prompt kill in less than a second.
    If this triggers and you’re anywhere nearby, you’re probably already dead. You just might not know it yet. The only thing that might save you is if the exposure time is less than a millisecond.
  7. The most useless device ever. If I had one and it went off, I’m already dead, and so is everyone else I care about.
    I’ve had enough of system support to last at least one lifetime. I’m certainly not interested in a post-mortem support task to keep anything else running for you lot.
  8. I simply leave an unlit candle by the windowsill. If the candle lights by itself, then a nuke probably went off nearby. It’s also useful for detecting housefires.
  9. The sensitivity of this device seems quite low, it really is a nuclear blast detector. Won’t serious EMP protection be required to ensure the Pico stays operational in this environment?
  10. My favorite part of the description is: “Its [the case’s] specialized polymer casing provides brief ablative cooling upon impact.”
    So the case (briefly) vaporizes, providing cooling. I appreciate the sense of humor! It is the little details that matter.
Leave a Reply to TruthCancel reply
