ELIZA Reanimated
The last time we checked in with the ELIZA archeology project, they had unearthed the earliest known copy of the code for the infamous computer psychiatrist written in MAD-SLIP. After a lot of work, that version is now running again, and there were a number of interesting surprises.
While chatbots are all the modern rage, [Joseph Weizenbaum] created what could be the first one, ELIZA, in the mid-1960s. Of course, it wasn’t as capable as what we have today, but it is a good example of how simple it is to ape human behavior.
The original host was an IBM 7094, and MAD-SLIP fell out of favor. Most versions known previously were in Lisp or even Basic. But once the original code was found, it wasn’t enough to simply understand it. They wanted to run it.
Fortunately, there is an emulator for the IBM 7094. MAD-SLIP is around, too, but for whatever reason, didn’t support all the functions that [Weizenbaum] had used. The 2,600 lines of code are mostly undocumented, and the only copy was on fanfold printer paper, so the first step was getting the text in digital form.
Once it was manually transcribed, they found some functions were missing in their MAD-SLIP version. Rewriting the functions and correcting a typo made everything work.
The original version had a learning mode that did not carry over to the later clones. There’s an example of how to teach new rules in the paper. You can also see a video (below) of the original code duplicating (nearly) the original published conversations from the 1966 paper.
We have been following the team for some time and they’ve made their work available if you want to try it. We have thought a lot about Eliza since the chatbots have started taking over.
8 thoughts on “ELIZA Reanimated
  1. Thanks for highlighting this. FYI, we’re next working on reanimating Simon, Newell, and Shaw’s Logic Theory Machine and other of the earliest true AIs, written at RAND and CMU in IPL-V in the 1950s. (IPL is an amazing lisp predecessor that looks like lisp’s assembly language! It’s ugly but fun!)
  2. Weizenbaum wrote a book about (among other things) his experience with the reactions that ELIZA elicited from the public: “computer power and human reason”. It is now unfortunately forgotten in the english speaking world (can’t have nay sayers in tech heaven, right?) and no one publishes it anymore (it’s still published in germany though, where I live). He was very critical of how people use tech and use or propose to use AI and basically already spelled out all the problems we now perceive with the use of AI in the present. If you can pick up a copy, go for it. In the first chapter or so he says that you can skip certain chapters that contain technical explanations. You can safely take his advice for a first read through.
    Unfortunately he’s dead now but maybe thats better for him. I think the present would have driven him insane.
Leave a Reply to SKYCancel reply
