PVA filament is an interesting filament type, for the reason that while it can be printed with any FDM printer, it supposedly readily dissolves in water, which is also the reason why PVA glue sticks are so popular when doing crafts and arts with young children. This property would make PVA filament ideal for printing supports if your printer can handle two different materials at the same time. So surely you can just pick any old PVA filament spool and get to printing, right? As [Lost in Tech] found out, this is not quite the case.
As an aside, watching PVA supports dissolve in water set to classical music (Bach’s Air from Orchestral Suite No. 3) is quite a pleasant vibe. After thus watching the various PVA prints dissolve for a while, we are left to analyze the results. The first interesting finding was that not every PVA filament dissolved the same way, or even fully.
The first gotcha is that PVA can stand for polyvinyl acetate (the glue stick) or polyvinyl alcohol (a thickener and stabilizer) , with the ‘PVA’ filament datasheets for each respective filament showing various combinations of both types of PVA. This results in wildly different properties per filament, both in terms of Shore hardness, their printability, as well as their ability to dissolve in water. Some of the filament types (Yousu, Reprapper) also have an outer layer and inner core for some reason.
Ultimately the message appears to be that ‘PVA’ filament requires a fair bit of research to have any chance of having a relatively trouble-free printing experience.
This is a neat video, but man is it confusing what filament you’re talking about at different times. Really could have benefited from a summery of what brand had what pros/cons/properties/whatever. Which one totally dissolved? Which one didn’t? Which one had a core? Which one was too brittle to print properly (or required different settings from the main print, necessitating a 2nd head)?
There’s some weirdness in the video also — such as the presenter’s commentary that the PLA dissolved before the PVA. PLA does not readily dissolve in water.
PLA is technically certified as biodegradable, though it’s pretty hard to get it to do that. As he notes in the video, “PVA” filaments can be two different things with the same acronym, and one doesn’t dissolve in water at all.
A reasonable point.
Reprapper and yousu had the core and thus partially dissolve.
Real filament appears to be pure PVA.
esun however prints the best due to its mix of PVA formulas.
None really printed well on a single head but the most likely to succeed would be the cored filament.
You have to qualify “PVA” with what you actually mean. There’s Poly Vinyl Acetate, which dissolves in water, and Poly Vinyl Alcohol, which does not.
One of the main takeaways of this video is that there are companies selling the latter plastic as if it were the former.
So it was the esun stuff that dissolved completely? But was also somewhat brittle and needed to be printed at a lower temperature?
