Linear Solar Chargers For Lithium Capacitors
For as versatile and inexpensive as switch-mode power supplies are at all kinds of different tasks, they’re not always the ideal choice for every DC-DC circuit. Although they can do almost any job in this arena, they tend to have high parts counts, higher complexity, and higher cost than some alternatives. [Jasper] set out to test some alternative linear chargers called low dropout regulators (LDOs) for small-scale charging of lithium ion capacitors against those more traditional switch-mode options.
The application here is specifically very small solar cells in outdoor applications, which are charging lithium ion capacitors instead of batteries. These capacitors have a number of benefits over batteries including a higher number of discharge-recharge cycles and a greater tolerance of temperature extremes, so they can be better off in outdoor installations like these. [Jasper]’s findings with using these generally hold that it’s a better value to install a slightly larger solar cell and use the LDO regulator rather than using a smaller cell and a more expensive switch-mode regulator. The key, though, is to size the LDO so that the voltage of the input is very close to the voltage of the output, which will minimize losses.
With unlimited time or money, good design can become less of an issue. In this case, however, saving a few percentage points in efficiency may not be worth the added cost and complexity of a slightly more efficient circuit, especially if the application will be scaled up for mass production. If switched mode really is required for some specific application, though, be sure to design one that’s not terribly noisy.
14 thoughts on “Linear Solar Chargers For Lithium Capacitors
  1. This looks nice and I have a few questions: Most LDO have a current output limit. I Don’t know how an empty supercapacitor can be described/characterized. Would it be safe if one assumes it behaves like a short when fully emptied? How does the LDO handle running into it’s maximum output current in that case?
    Yes, I’m asking the experts! I’m clueless on this one. Please tell me if this approach is safe for my hardware if I should rebuild it. Explanations welcome if you have a minute extra.
    1. Solar cells basically act as a constant current source. The load from the capacitor will drag down the voltage of the solar panel to the capacitor voltage + the dropout voltage of the LDO. As long as the current rating of the LDO is higher than the short circuit current of the solar panel, it shouldn’t be an issue.
      If you want to charge from something other than a small solar panel, you will need a proper battery charging circuit.
      1. That explain how to charge the capacitor, not how to limit the voltage of the capacitor to stay within expected range. A 5V solar panel can output more than 5V when no current is drawn, (like when the capacitor is full), yet your capacitor are limited to 4.2V. Similarly, if you let the system idle on a cloudy day, it’s likely that the capacitor voltage will go below ~2.5V (or so) that would kill your capacitor as well. You need a controller power source that’s able to isolate completely the capacitor in case it’s either full or empty, not something you can do with a LDO. You need to be able to draw switch off the solar panel and switch on the load current from the capacitor when it’s full so its voltage can decrease, and switch off the load and on the solar source when it’s empty so it can resume its operation (with hysteresis). In all cases, you’ll need a switching regulator.
  2. Here the solar cell is the limiting factor for current, but what if you want to charge a lithium capacitor from batteries? Suppose for example that your device needs high current for a short while but the battery is something like a lithium thionyl cell that can’t supply it without crashing the voltage down, especially at lower temperatures. Therefore you need a big capacitor.
    So you need three things: 1) very low voltage loss, 2) charging current limiting, 3) back-charging current limiting or blocking to prevent accidents when replacing the battery, like a reversed cell or accidentally swapping in an empty cell.
    and 3. could be handled with an ideal diode chip, but 2. is more difficult. When you first slot a new battery in, it could draw several amps and the linear regulator could go pop.
      1. I wonder if that can damage the cell. The spec sheets state that high currents at low temperatures result in a loss of capacity.
        Or, this could be a regular lithium cell that limits the current when cold, but not when it’s warm.
      2. A similar problem applies to the resistor as well. Suppose you want to charge the capacitor at 500 mA – the resistor will see 2 Watts of heating when the capacitor is empty. For normal capacitors this wouldn’t be an issue because they’re very small, but if you have like 500 Farads of capacitance to charge then it’s going to be a while and a surface mount resistor will get hot enough to desolder itself.
        Of course, add more resistors to share the load, but then that’s more parts to lay down.
        1. Or, even if you have normal 1/4 Watt through-hole resistors, you still need eight of them.
          It is doable with resistors, but you need to limit the charging current quite low and that means the capacitor can take hours to charge before it can start operating. It also means the device can’t be operating very often or the capacitor doesn’t have enough time to charge back up between uses.
        2. If you’re having to add massive resistors to handle inrush current, it’s not likely your overall design is going to be all that efficient designed around an LDO. Switchers had better be able to operate into a dead short indefinitely and usually fairly efficiently: their bete noire is conversion efficiency at low loads (like maintenance/trickle charge loads.)
          Or if you really want some fun, use a switcher for heavy source/load mismatch, and when your difference is low, then switch to the LDO.
    1. Thanks for the insightful post! I’ll be sure to check the specs of my solar cell to see if it could damage the LDO if the output draws too much from it. I had considered adding a constant current circuit first but the added complexity probably makes it less efficient. Some people use two LM317(T) in tandem to have constant current and constant voltage. Probably with diminishing returns.
      Either way this is a nice subject for me to learn more. Some energy harvesting ICs seem to already include protective logic and circuits, but they are too proprietary to understand what they do inside.
    1. Exactly and a maximum voltage too. This design is a guaranteed failure of the LiC. LiC have a minimum voltage and a maximum voltage. They have a lower current capacity than EDLC supercapacitor and a lower cycle life (you can’t derate them to boost the cycle life like a EDLC would do). Their only advantage compared to EDLC is their size and low self discharge rate. But, in fact a LTO cell will likely work better here, with a much higher capacity, a similar cycle life count, a larger current capacity, a larger temperature range and a lower self discharge rate (in µA instead of mA) and a lower price.
  3. Since the solar panel output voltage is well matched and just above the desired capacitor voltage, best efficiency and simplest approach at these low currents may be to directly connect solar panel to capacitor and then use a parallel zener diode / LED / LDO arrangement to limit the charge voltage by SINKing current above the fully charged voltage. Like going downhill in a car and using brakes to limit speed.
Leave a Reply to DudeCancel reply
