SparcStation 1+ Finally Gets Attention
We can’t throw stones. [Leaded Solder] picked up a SparcStation 1+ in 2018 and found it only produced illegal instruction errors. We’re sure he’s like us and meant to get back to it, and, instead, it sat on the bench, taking up space. You eventually have to move it, though, so seven years later, it was time for another go at it.
The first pass back in 2018 revealed that the machine had an interesting life. The full-sized hard drive was salvaged from an Apple computer. Removing the drive resolved the illegal instruction error. The drive seemed to work, but there was still nothing that suggested the machine would fully boot up. The next step was to try booting from a floppy, but that didn’t work either. The floppy cable had been surgically altered, again hinting this machine had seen some tough love.
Fast forward to 2025. This time, a Pi Pico-based SCSI emulator would stand in for the aging and suspect hard drive. Unfortunately, as noted, this machine has undergone some extensive and strange surgery. The power cable feeding the emulator had been rewired backwards, exposing the poor Pi Pico to 12 V, with predictable results. Luckily, it didn’t seem to phase the SparcStation.
The machine has some hard-to find micro fuses and one that powers the SCSI bus was blown. You could wonder if the SCSI emulator blew the fuse, but it appears it didn’t. Pulling the Ethernet fuse and placing it in the SCSI slot improved the machine’s behavior. But the termination power was still a problem. A USB cable temporarily solved that and, in fact, got the machine a little bit further.
That’s as far as he got this time. We’d imagine if you know a lot about this computer and have ideas on how to solve some of the remaining problems [Leaded Solder] would be glad to hear from you. But take your time. We estimate you have at least a few years.
There was a time when every geek wanted a Sun computer. Of course, if this is too much work for you, there’s always emulation.
12 thoughts on “SparcStation 1+ Finally Gets Attention
  1. I resurrected an SGI Indigo. Root password unknown, and it’s surprisingly hard to reset it. I ended up being lucky — some demo usernames were still on the system, no password required, so I dumped /etc/passwd and used a cracker to get the root password (remember, this OLD Unix)…right about the time our system manager came up with it :-) It was originally a mechanical CAD system, long since superseded by Windows and SolidWorks.
    I bought another SCSI HDD off eBay to preserve the original one, and found CD images for the OS, which I installed over the network…after I had arranged the keyboard, mouse, video and network adapters. Thank goodness for tftp. It’s a neat little retro system, and as far as I can tell, the demos are all there.
    It runs, but for some reason, SGI made the C compiler and extra cost, licensed option. Ugh. I have a copy of the licensed compiler but it uses network licensing and a license server, which I have not set up. GCC will supposedly work, but that would mean a non-standard system, and I’d rather have it as original as possible.
  2. Googled and my GOD! The prices are insane. I think I paid like $15 for mine. Check the surplus places and ask around. Cheapest I saw was $40, which seems outrageous. These things were ubiquitous when 10BASE-T replaced the old thickwire.
  3. I was a sys admin for a resonably large SUN installation. I have at least a IPC and SLC motherboard. Sadly i did not have room for my sun 2/120 to take home
    I have probably one or 2 sparkstations in the attic.
    SCSI cd player and some other stuff 😀
    Like a vme card controller for a tape station.
    The first Sun I used was a sun 1 one of the 3 brought to sweden by Ericsson technical director.
    I was part of the team that tried out PERC, Apollo, HP and Sun work stations for programmer work stations.
    1. are you sure about that? I seem to recall “boot fd” being a thing, and the SunOS 4 installer coming on a stack of floppies.
  4. I still have my SparcStation 20 w dual Ross processors (don’t recall the speed). I like to fire it up once in a while and run the Xmaze demo.
  5. I have a behemoth Sun 4/280 “server” system (first-gen Sparc CPU) in my collection of Sun machines. It has three SMD-interfaced 8″ Hitachi 300Mb hard disk drives(that make a really scary noise when they perform their power-on seek test, sounds like an earthquake is coming), a 16-Port Serial board for hooking up terminals or modems, serial console port hooked up to an old Xylogics Micro Annex terminal server so I can connect to the -console- over Ethernet using telnet, a 9-track Pertec-interface 1/2″ tape drive, a 1/4″ SCSI QIC cartridge tape drive (for loading install media – no CDROM in those days), a 5 1/4″ full-height SCSI drive (980Mb), 48Mb of RAM, AUI port for 10 megabit Ethernet (with an adapter to convert it to 10BaseT RJ-45), all mounted in an original Sun rack, running good-old, unpolluted, SunOS 4.1.3U1. It will heat the building to a comfortable temperature on a cold winter morning within two hours. I fire it up from time to time just to re-live the good old days where computers were much less of a pain in the ass than they are today. I’ll usually play some classic ‘rogue’ on it for a while, or fire up an X server on my laptop and play some of the classic X-based games. Unfortunately, my electric bill can only afford occasional time travel.
Leave a Reply to Bo-Erik SandholmCancel reply
