If you’ve been following the hubbub about 3I/ATLAS, you’re probably either in the camp that thinks it’s just a comet from ridiculously far away that’s managed to find its way into our solar system, or you’re preparing for an alien invasion. (Lukewarm take: it’s just a fast moving comet.) But that doesn’t stop it from being interesting – its relatively fast speed and odd trajectory make astronomers wonder where it’s coming from, and give us clues about how old it is likely to be.
Astronomy is the odd-man-out in the natural sciences. In most branches of physics, chemistry, and even biology, you can run experiments. Even those non-experimental corners of the above fields, like botany, for instance, you can get your hands on the objects you’re talking about. Not so astronomy. When I was studying in college, one of my professors quipped that astronomers were pretty happy when they could hammer down a value within an order of magnitude, and ecstatic when they could get a factor of two or three. The deck is simply stacked against them.
With that background, I love two recent papers about 3I/ATLAS. The first tries to figure out why it’s moving so fast by figuring out if it’s been going that fast since its sun kicked it out, or if it has picked up a gravitational boost along the way. While they can’t go all the way back in time, they’ve worked out whether it has flown by anything close enough to get a significant boost over the last 10 million years. This is impressive that we can calculate the trajectory so far back, but at the same time, 10 million years is peanuts on the cosmic timescale.
According to another paper, there is a weak relationship between interstellar objects’ age and their velocity, with faster-moving rocks being older, they can estimate the age of 3I/ATLAS at between 7.6 and 14 billion years old, assuming no gravitational boosts along the way. While an age range of 7 billion years may seem like a lot, that’s only a factor of two. A winner for astronomy!
Snarkiness aside, its old age does make a testable prediction, namely that it should be relatively full of water ice. So as 3I/ATLAS comes closer to the sun in the next few weeks, we’ll either see it spitting off lots of water vapor, and the age prediction checks out, or we won’t, and they’ll need to figure out why.
Whatever happens, I appreciate how astronomers aren’t afraid to outline what they can’t know – orbital dynamics further back than a certain date, or the precise age of rocks based solely on their velocity. Most have also been cautious about calling the comet a spaceship. On the other hand, if it is, one thing’s for sure: after a longer-than-10-million-year road trip, whoever is on board that thing is going to be hungry.
Not sure about little Green Men, but there sure is a lot of little green click-bait on the net about all three comets in sight right now. Makes for a good distraction ahead of the next manufactured world changing event.
The things you here on the talk radio scene by People who should know better (Harvard Yah you) proves you cannot trust anything you hear on major name talk radio shows.
GIGO
Comets are fascinating and amazing, I’m happy some things still are :-)
100% with you on that….
Had astronomy back in college in the mid 70s really enjoyed it.
Astrology is as much science as psychology is… shame on HaD for publishing such low quality articles. If you can’t repeat an experiment in controlled conditions then it isn’t science, period.
Ideally, yes, but practically, not so much: There are sciences that study the past and sciences that study large-scale or rare natural occurances that can’t be created in a lab that by your strict defintion are not science.
I’m thinking most sciences related to archeology and palientology, most sciences related to larger-than-lab-scale weather events, anything in space beyond where mankind can visit, and more.
You may be able to claim “repeatability” with some slop for things like “we studied records from 500 tornadoes from 1970-1980 and found …, then we studied 500 more from 1980-1990 and found the same thing” but rarely if ever could you claim the science was done “in controlled conditions.”
Astrology isn’t science at all. But you may be referring to astronomy. Astronomy has plenty of testable repeatable experiments – just look at the expansion rate hypothesis and use of detected novas.
Depending on the subfield – psychology is also most definitely science — there are many examples of testable repeatable psychological experiments.
An age of 7.6 to 14 billion years old is kind of a cheater’s way to get a factor of two, since the latter is the age of the universe itself. :)
It seems that almost (?) all of the fooferall about this object emanates from Avi Loeb, a well credentialed well published astro nomer or physicist who unfortunately seems to have gone crazy about the topic of extra-solar objects. His goto explanation seems to be “spaceship”.
As for tracing the trajectory back, it seems to this reader that that necessarily assumes “and no interesting catastrophic events took place in the object’s (astronomical) vicinity for the last 10 million years.” Extraordinary, Captain. Extraordinary assumptions require extraordinary suspension of disbelief. Sadly Agent Mulder’s scripted line was always “I want to believe” rather than “I want to know”.
“Even those non-experimental corners of the above fields, like botany,“
Did you enjoy dinner? Thank a botanist. Genetics? Thank a botanist. Arabadobsis Thaliana for the win. https://en.wikipedia.org/wiki/History_of_research_on_Arabidopsis_thaliana
“No one would have believed, in the early years of the twenty first century, that human affairs were being watched from the timeless worlds of space. No one could have dreamed that we were being scrutinised as someone with a microscope studies creatures that swarm and multiply in a drop of water. Few men even considered the possibility of life on other planets. And yet, across the gulf of space, minds immeasurably superior to ours regarded this earth with envious eyes, and slowly, and surely, they drew their plans against us…”
Ah the classics.
