Few people know LLMs (Large Language Models) as thoroughly as [Andrej Karpathy], and luckily for us all he expresses that in useful open-source projects. His latest is nanochat, which he bills as a way to create “the best ChatGPT $100 can buy”.
What is it, exactly? nanochat in a minimal and hackable software project — encapsulated in a single speedrun.sh script — for creating a simple ChatGPT clone from scratch, including web interface. The codebase is about 8,000 lines of clean, readable code with minimal dependencies, making every single part of the process accessible to be tampered with.
The $100 is the cost of doing the computational grunt work of creating the model, which takes about 4 hours on a single NVIDIA 8XH100 GPU node. The result is a 1.9 billion parameter micro-model, trained on some 38 billion tokens from an open dataset. This model is, as [Andrej] describes in his announcement on X, a “little ChatGPT clone you can sort of talk to, and which can write stories/poems, answer simple questions.” A walk-through of what that whole process looks like makes it as easy as possible to get started.
Unsurprisingly, a mere $100 doesn’t create a meaningful competitor to modern commercial offerings. However, significant improvements can be had by scaling up the process. A $1,000 version (detailed here) is far more coherent and capable; able to solve simple math or coding problems and take multiple-choice tests.
[Andrej Karpathy]’s work lends itself well to modification and experimentation, and we’re sure this tool will be no exception. His past work includes a method of training a GPT-2 LLM using only pure C code, and years ago we saw his work on a character-based Recurrent Neural Network (mis)used to generate baroque music by cleverly representing MIDI events as text.
this is not usefull, but adapter on any middle model is very usefull today.and You can todo this on 5090
I’ve not looked into LLM too deeply, beside running a few small models offline, and using ChatGPT to solve tricky word puzzles from Blue Prince. These advantages are quite interesting and may be what is needed to create very specific and useful models. In my case, I’d like to put in my own knowledge base and vetted sources on locks, lock picking, and physical security. Possibly in combination with embedded security and electronics, as those are my knowledge fields. It won’t be a model I can share, but it may be able to help me find tricky connections and deep insights.
As an experiment, I would like to see the LLM trained on just the whole of HackaDay and the projects they use as content. You may not be able to publish the dataset or model, but at least HAD can share how well it works. Similar other institutions could do the same.
I only consent to my comments being read, not processed and analysed.
Sorry I inadvertently processed and analysed your comment after reading:)
Check the Terms of Service at the bottom of every page:
“you grant […] SupplyFrame an irrevocable, nonexclusive, royalty-free and fully paid, worldwide license, with the right to grant sublicenses, to reproduce, distribute, publicly display, publicly perform, prepare derivative works of, incorporate into other works, and otherwise use the User Content for purposes of operating and providing the Service to you and to our other users.”
Sounds to me like we’ve already consented to Hackaday/SupplyFrame doing that kind of thing.
LLM invent and build me affordable house I can live in.
Reminded of when Arstechnica did their experiment with cryptocurrency, back in the day. Now it’s LLM’s turn.
I saw this elsewhere yesterday and decided to dig into the source code posted to GitHub. The project is written almost entirely in Python. If this is standard practice for LLM training, it could help to explain, at least in part, the large amount of computing power and ultimately electrical power required for the training process. Python is an interpreted language that can be orders of magnitude less efficient than a compiled language like C. Am I missing something?
Yes, you are. Python is a high level language just used to direct things happening at a lower level. All the computation is happening in compiled libraries written for efficient execution on the target hardware. Those libraries are written in C, or CUDA, or something else as the case & target hardware varies.
And to complete there is a little part in Rust to accelerate some “tokens manipulations”
Yes, you are missing a key detail – much of research into NNs is done in Python using a library called PyTorch, a library which is implemented in lower level languages. The computationally expensive components are running much faster than interpreted Python, with the option of even running on GPU.
The majority of the cost is not going to evaluating Python – it simply is just that expensive to run training on large parameter models.
Oh man, you looked at some code for a moment and solved a multi-trillion dollar problem the AI industry is facing. Why didn’t anyone else think of not writing code in python?!?
The part where Python is most significantly used to shuffle data in and out.
It, generally, isn’t doing the heavy lifting when it comes to AI fields.
Yes. The actual computations is usually done by well optimized machine code, mostly running on GPUs or even ASICs. Python is just the glue that manages and directs the whole show.
C and Python are fundamental to LLM as we know it today. C bc you need that to write your own Python libraries. I’m sure OpenAI and it’s peers have looked at faster options, but it’s silly to pay to make what the Python community has provided for free to the AI industry.
Hey, are replies broken? Above commend was for @Bob
AWS outage
It is discouraging to realize training requires commercial grade GPU to achieve. Some LLM can run on surprisingly low specs, but those same LLM required an AWS rental and not insignificant cash flow to produce. When I can train on low spec hardware, then AI will be in a useful state
You can of course train useful AI on low spec hardware. I was doing that more than 20 years ago. It’s even more viable today. But what you can’t do is train arbitrarily complex AI on low spec hardware.
Has someone calculated how long would it take to train this model in a single rtx3060? My back-of-napkin calculations point to around 200 hours, or slightly over a week. Does this sound correct?
To my understanding – which is likely naïve, so I welcome correction – H100’s are 989 TOPS each and he is using eight of them (8 x H100 not 8XH100). An RTX3060 by comparison is 101 TOPS.
So 78 times more powerful in raw computing numbers only; ((989/101)8)4 is ~313 hours or ~13 days.
however it doesn’t scale in this linear fashion as you have WAY less memory (6GB vs 94GB), and with swapping and so on, this likely increases significantly – if it’s even possible.
There is also the paralellism of the eight x H100s and thermal throttling of your 3060 and the power of the underlying hardware orchestrating the entire shebang.
The array is about US$10 an hour to rent, so not that bad.
there is also an company where people can rent out their own gpus, if i’m not mistaken a H100 can be rented for US$1/hour there
