Built-In Batteries: A Daft Idea With An Uncertain Future
Having a gadget’s battery nestled snugly within the bowels of a device has certain advantages. It finally solves the ‘no batteries included’ problem, and there is no more juggling of AA or AAA cells, nor their respective chargers. Instead each device is paired to that one battery that is happily charged using a standardized USB connector, and suddenly everything is well in the world.
Everything, except for the devices that cannot be used while charging, wireless devices that are suddenly dragging along a wire while charging and which may have charging ports in irrational locations, as well as devices that would work quite well if it wasn’t for that snugly embedded battery that’s now dead, dying, or on fire.
Marrying devices with batteries in this manner effectively means tallying up all the disadvantages of the battery chemistries and their chargers, adding them to the device’s feature list, and limiting their effective lifespan in the process. It also prevents the rapid swapping with fresh batteries, which is why everyone is now lugging chunky powerbanks around instead of spare batteries, and hogging outlets with USB chargers. And the task of finding a replacement for non-standardized pouch cell batteries can prove to be hard or impossible.
Looking at the ‘convenience’ argument from this way makes one wonder whether it is all just marketing that we’re being sold. Especially in light of the looming 2027 EU regulation on internal batteries that is likely to wipe out the existence of built-in batteries with an orbital legal strike. Are we about to say ‘good riddance’ to a terrible idea?
Not Very Pro
The Nikon EL-EN15 battery.
To further rub in how much of a terrible idea built-in batteries are, one only has to look at professional equipment, particularly in the audiovisual world. Whether we are talking about DSLRs, mirror-less cameras, or professional video cameras, they all have as standard feature the ability to quickly swap batteries. Nikon and Canon cameras use a range of proprietary-but-standard Li-ion batteries, with Sony’s video camera batteries also used on portable studio lighting. For the super-expensive Red video cameras you can use either the massive Redvolt batteries that dangle off the side or a power adapter.
The reasoning here is simple: when you are doing a photo or film shoot you do not have time for charging, so you load up with a stash of charged batteries beforehand. As the current battery becomes drained, you pop open the battery hatch or detach the current pack and slam in a fresh battery before resuming. During moments of downtime you can put the drained batteries on the charger that you have squirreled away somewhere. This way you stay wireless and charged with zero fuss, and if you have enough batteries, zero downtime.
Even within the era of budget photo and video cameras you’d be able to do this. When it comes to my own JVC camcorder and Canon IXUS 100 IS point-and-shoot camera, both offer this feature, even if the battery swapping experience doesn’t feel as premium as with the Nikon D7200 DSLR and its EN-EL15 batteries that is used for more serious occasions. Swapping batteries with the DSLR in particular is as easy as swapping SD cards, which is to say a matter of seconds.
One might get the idea here that the main reason to stuff a pouch cell somewhere inside the device is mostly a cost-saving measure, as it omits the battery terminals and ejection mechanism for the pack.
Battery Decay
Another reason why having a built-in battery with a multi-thousand-Euro DSLR would be a terrible idea beyond the insanity of having to ‘charge the DSLR’, is that the battery will be dead long before even the warranty on the DSLR has expired, especially if you are an avid shooter. Even if you do not use a device that much, the fact of the matter is that lithium-ion cells begin to degrade as soon as they have been manufactured. This may be acceptable in a €1,000+ smartphone when people buy a new one every other year anyway, but becomes a problem when you’d like to use a device for much longer.
A good summary of the how and why of lithium-ion batteries (LIB) can be found in this IEEE review article by Wiljan Vermeer et al. from 2021. The three main aging mechanisms are:
  • Loss of Lithium Inventory (LLI).
  • Loss of Active Material (LAM).
  • Conductivity Loss (CL).
There are multiple ways in which each type of aging can occur, with most requiring the cell to be charged and discharged, as this inflicts mechanical and other types of stress. When it comes to storing LIBs, we enter the territory of calendar aging. This has an irreversible and reversible component, the former being impacted by three components: the state of charge (SoC), temperature, and time.
Calendar aging of NMC Li-ion cells at 50 ℃ and at various SoCs. (Credit: Wiljan Vermeer, IEEE, 2021)
What this tells us is that although you can affect LIB calendar aging, it’s a pretty inevitable aspect of their chemistry. This is true even in the case of the lithium-polymer (LiPo) LIB type batteries with its polymer electrolyte. This effectively means that charging the battery in a device to 80% instead of 100% will give it some more life, but you’d have to drop down to 50% or less to see the big gains. It’s also highly advisable to keep the battery relatively cool, which is where fast-charging is a terrible idea, especially as the resistance of the battery goes up due to aging.
While the exact mechanisms behind calendar aging are still being investigated, it’s likely that the layer that forms at the electrochemically unstable electrolyte-electrode interface (SEI) restructures to prevent the transfer of lithium ions, effectively increasing the measured resistance via the CL aging path.
In addition to calendar aging you have the charge-discharge cycle-based aging mechanisms, which not only affects the SEI, but also causes mechanical expansion of the graphite anode material, which leads to both the LLI and LAM aging paths. When you then add in the typical charging method for gadgets like smartphones using a LIB-based powerbank, you end up with double the charge-discharge cycles over simply slotting in a fresh battery.
End Of The Road
Replacing the battery in the Samsung Galaxy Nexus. (Credit: Maya Posch)
Beyond larger electronic devices, pouch cell LIBs are now integrated in countless more gadgets, from lamps to Bluetooth speakers. To address the sheer volume of these built-in LIBs, the EU’s Battery Regulation will begin to enforce its removability and replaceability requirements starting on 18 February of 2027.
The batteries which we discussed in this article fall under so-called ‘portable batteries’, meaning that it weighs less than 5 kg and is not used for an electric vehicle. These are required to make it possible for the end user to replace and remove, all without damaging or destroying the battery or the device, and without requiring any special tools. There are some partial safety-related exceptions where a professional can do said replacement, while a full exception is limited to a number of very specific device categories.
What exactly the fallout of this change will be remains to be seen, with manufacturers likely starting to adapt their products throughout 2026. Devices like smartphones, game controllers, but also Bluetooth speakers, wireless mice and portable game consoles will all be affected, so it’ll be interesting to see what approach we will see here.
Perhaps most of all what it might mean for standardization of cells and batteries, as every device that’s put on the market in the EU must have spare batteries available for reasonable cost for five years after it stops being sold. Clearly this would be cheaper if the same battery just got used for decades, somewhat like the veritable AA cell and today’s 18650 and similar formats.
So Many Standards
The process of standardization is a rough one, with sometimes the legislature leaning into the issue after consultation with a requirement, as with USB-based chargers. Other times the market simply picks something that’s readily available and does the job. One example of this is the Nokia BL-5C battery and its variations, which was quite prevalent due to Nokia using it for its phones and other platforms like the N-Gage. Consequently third-party manufacturers made their own compatible versions for use in a wide range of devices.
The Nokia BL-5C Lithium-Ion battery, this one from a Nokia N-Gage. (Credit: Evan-Amos)
While the BL-5C is still fairly large, at 53 mm x 34 mm and a thickness of 6 mm, point and shoot cameras as well as action cameras feature a range of smaller batteries, with the Canon NB-4L as used in the IXUS point and shoot cameras providing more than 750 mAh in a 35 mm x 40 mm package and a similar 5.9 mm thickness. The third-party replacements that I got of the NB-4L claim to provide 1,200 mAh, as modern LIBs tend to have more capacity within the same form factor due to more refined manufacturing.
Interestingly, even rechargeable AA-sized cells aren’t limited to NiMH chemistry any more, with Li-ion options now available yet still providing the 1.5 V one would expect. This does require a bit of electronics in the cell, and results in them having a capacity that’s similar to that of NiMH AA cells, while suffering all the aging issues of any other LIB in addition to the limited number of charge cycles. Assuming that the 1.2 V of NiMH cells is acceptable, then devices could accept AA or AAA NiMH cells.
Of note here is that none of this means that having a power input port for charging the battery or cell inside the device itself is no longer possible or allowed. Depending on the device manufacturer, the new EU regulations should mean little difference for the end user, other than having the option to pop open each device to extract and replace the battery. This could mean that wireless mice and Bluetooth headsets will soon feature an alternative to sticking in that charge cable and have the device be mostly useless until its built-in battery has soaked up sufficient juice.
Although this is an EU-only thing, it’s likely to come to every other part of the globe as well.
48 thoughts on “Built-In Batteries: A Daft Idea With An Uncertain Future
  1. the EU’s Battery Regulation will begin to enforce its removability and replaceability requirements starting on 18 February of 2027.
    Good.
    My previous wireless headphones got 15 years of use by swapping out worn NiMH batteries, until I sat on and broke them. My present wireless headphones will become useless after 5-6 years, because the manufacturer explicitly told me when I asked them, that it would become a risk if I continue using them after the built-in lithium cells wear out. I paid good money for these headphones with the option to plug in a wire to continue use when the batteries go empty, which would at least let me use them for longer, but that’s a moot point if they might catch on fire while I’m wearing them.
    Embedded lithium batteries = planned obsolescence.
      1. How does a person go through their entire life seeing dollar-sign-followed-by-number everywhere (except where ignorant people are involved) and yet do the ignorant “30$” thing? Please tell me you don’t vote…
      1. I did not attempt to get into the device to see if I can do that, at least while it’s still working. The battery appears to be well glued in under several layers of rubber and plastic. Whether the BMS will accept the new cell, and whether it will apply the correct charge limits is another question entirely.
    1. Embedded lithium batteries = planned obsolescence.
      Only in some cases – or there embedded and then EMBEDDED devices.
      As loads of devices with inbuilt battery area really easy to change when you need to – for instance I understand the latest revisions of the Steamdeck have improved the battery adhesive that made removing the old battery very hard in the first batch and all you need to get into one of those is a smaller Philips screwdriver. Though i suspect by the EU’s definition that will mean it actually doesn’t have to change at all – and frankly it shouldn’t need to as the battery will last you a good long while.
      Then you get the wireless earbud type things where as a rule the only way to get into them at all is destructively as whatever method used to put them together is one way. I’d suspect your headphones are probably more towards the steamdeck side of things, as most of the headphones I’ve seen while annoying to work on can be worked on if you are careful.
      1. I found the type code of the battery cell online, but I could not find any source where I could buy the exact model. What other models would fit, who knows?
        Buying one now is also not a good idea, because it would just be sitting on the shelf going bad – so this remains a problem for future me in a few years when it’s even less likely that this exact battery can be found anywhere. It may still exist, but under a different type code from a different manufacturer, and good luck figuring that out.
        This is why the replaceable battery regulation makes sense: it would demand the creation of new battery class, type and format standards that manufacturers could use instead of making up yet another proprietary battery with a special connector that can’t be bought after the product exits the market. The 5 year limitation doesn’t help here, since batteries last longer than 5 years – but only just – so the last people to buy the product are still shafted.
  2. I think i want to see a lot of the changes this article recommends but it really comes down to usage.
    A professional camera needs to be usable for the entire duration that you can afford to staff it. You can tag-team cameramen in shifts, one operator after another, and run it 24/7, so you need to be able to refresh the battery on that same schedule. But my phone, i never use it like that. I charge it about once every 4 days.
    But then i get to re-purposing phones, and suddenly i care again. A phone that is unused for a while will puff up. A phone that sits on the charger 24/7 will usually roast its own battery. A phone that you’ve removed the battery from will refuse to power on. A phone that’s been re-purposed as a traffic monitoring camera needs a powerbank to have many hours of always-on, just like a professional camera does.
    Of all those, the one i resent the most is the inability to turn on once the battery has been removed. Almost every single repurposing project runs into that one. The original battery needs to be thrown out and the new use case is compatible with tethering to AC or to a powerbank, but i just can’t do it (easily). I hacked my Nook to hang on the wall without a battery, but i guess my hack was braindead somehow because it turns itself off about once a week, complaining that there’s no battery.
    Sigh. Anyways, anything is better than a flashlight with replacable AA batteries that nonetheless fails when the batteries run dry because they spew lye all over the contacts, and/or gets physically wedged in there so it destroys the thing to pull them out.
  3. i already have a multi-chemestry charger on my desk that can handle 18650s. sticking on a battery management circuit isn’t that difficult. ive seen a couple methods. the first, the one i use, little strip pcbs that you can spot weld to either end through zinc tabs and put a heat shrink over it. this makes them not quite cylindrical and requires a little bit of clearance and a strip of kapton tape for insulation. other method is an end cap circuit which can either be integrated into the cell itself or as a press fit add-on. depending on which is used may add some length to the cell. though im pretty sure factories could integrate then in the accepted form factor without too much retooling of the lines.
    im not sure how that works in multi-cell packs. parallel packs would probibly be easier to do and use a simple management board, but if you need a series pack then you need some balancing which may not be available in simple single cell bmses. when you have a bunch of cells which may be differently aged and at different levels of charge you add a whole new layer of potential failure modes, and this time the industry can buck the blame to user error rather than design flaws.
  4. IMHO, another case where “everything is integrated” is a terrible idea. Integrated things fail integratively, ie, as one unit in one move.
    It’s been a long road from “batteries included” to “batteries not included” to “batteries embedded” (for no good reason other than making things fail permanently at whatever moment they decide to fail).
    Invent me a tiny pico-fusion-reactor embedded in a car already. The one I got laughed at at the other topic Z-Pinch fusion reactor with all the fuel it needs for the life of an EV. Better yet, a Z-Pinch fusion reactor that can power a house for a family of four, ready set go, EV that can power a small house, TVs, driers, whatever.
    Cell phones are last century invention, btw. Time to move forward to something else, better, cheaper, say, houses built by AI “agents” on designated spot, overnight, zero labor costs, only the cost of raw materials and delivery (by automated trucks). Similar local AI “agents” should be making the said “raw materials” locally, not from overseas, and delivering them to all willing, DIY crowd, whomever. While at it, replace pointless congress politicians with people-controlled humanoid robots that could not be commanded by Big Bad Corporations, presto, problem solved, zero salaries, zero spending, endless profit for average Sam. If I don’t like what one of those robots is saying/doing, I remote to it and shut it off (or reprogram the way I need it to work to represent ME, actual human).
    1. zero labor costs
      That’s already the case, or close to. For many items you use every day, labor costs are under 10%. But then the retail cost is not. You see, when people don’t earn money by making things, they make money by selling things, and many more people can join in that game hand-in-hand, demanding all sorts of payments along the way, or turning the products into services…
      1. Or, to put it otherwise, even when robots make things, the cost of people doesn’t go away.
        The people will find ways to earn the money to buy the products, whether that’s by adding their cost on top of the price, or by demanding money from the government which then taxes the products to pay it. What that means, you’ll be paying for both: the robots and the people.
        It’s a far better idea that people make the products rather than sit idle and invent make-work to get paid.
    2. IMHO, another case where “everything is integrated” is a terrible idea. Integrated things fail integratively, ie, as one unit in one move.
      Most things fail in the same fashion, even with hot swappable battery the device “fails” if you don’t have a good battery at hand because it still requires it work. The car is broken if one of the brakes is locked open/closed, the spark plug fouled etc.
      The only thing that really matters is where it falls on the design for servicing or design for forced obsolescence sliding scale. With a small side question of expected lifespan – there is no point in definitively short lived devices being built to last a few centuries with proper maintenance if the need for them is only to live a few hours, and if something really should last many years it better be built to get whatever maintenance it will need.
      1. IMHO, cars is not the best example, since they HAVE to be maintained, brakes, spark plugs, etc. Even though average car appears to be highly integrated, it is really “loosely coupled” – one can drive with one spark plug gone (I’ve done that, even with 4 cylinder engines), and brakes don’t just readily fail unless they are in terrible shape due to many, many years of regular use/abuse.
        The example I hate the most is the modern cars’ computers where EVERYTHING, even the “entertainment system” is run through the same central unit. To me that’s single point of failure asking for trouble to happen (cell rot sooner or later WILL start introducing all kinds of weird intermittent errors that will be unique to a particular car). We’ve split hairs on this topic elsewhere, but the gist is this – critical systems like ignition SHOULD BE separate from the entertainment system or door locking or anything else that’s not related to ignition. Price for the average chip that goes into average Sam’s car has gone into mostly $5 per chip territory (compared with, say, 1980s Chrysler cars), so there is no longer any sense in forcing it to be “one central unit”, and it will make more sense to make it modular, too, plug-in non-critical modules that one can replace and/or upgrade. Aircraft industry knows how to handle that, and they also know how to backup systems WITHOUT making them cost as much as a new airplane.
  5. On one hand, yes, great idea.
    On the other hand, unfortunately people buy cheap crap, and unless the EU can magically halt the flow of dangerously badly made 18650 cells (good luck; they haven’t so far. Their rules only apply to people who want to comply, and increasingly only to certain US companies…) then this seems like a recipe for more house fires when people inevitably get cheap offbrand crap batteries and abuse them.
    1. My elderly neighbor had a cheap chinese radio with solar cell built-in. It worked until its tiny 6V lead-acid battery became worn. He asked me to repair it. After looking for a matching battery I told him, cost of new battery will be higher that buying a new radio of the same make and model.
      He then went to a local bazaar and bought some cheap no-name 18650 cell. He asked me to solder it instead of that lead-acid battery. I refused and warned him about that “upgrade” because: this radio doesn’t have a proper charging circuit for lithium cells which creates a risk of fire; I don’t have a spot welder needed to make proper connections to the cell’s terminals.
      He then got angry, said something something you university kids don’t know anything and decided to do it himself, using transformer soldering iron from early 1990s.
      Two weeks later his summer home burned down. He never spoke to me again.
      1. IMHO, horrible story, and LiPo chargers for 18650 are literally less than a dollar (some can be scavenged from trash). Terminals are not needed, as there are $1 18650 holders that work reasonably well. Some 18650s come pre-soldered with wires, and some even have charge/protection circuit built in.
        I this he was right about university kids. He probably also mentioned that nobody makes any good radios any longer, and he is 100% right, too, everything is on them internets nowadays.
        “never spoke to me again” is probably related to not being able to converse in a way that delivers results.
        Radio (and over the air comms in general) has its rightful place, and it is a pity we in the US tend to destroy what works without a meaningful/rightful replacement (Space Shuttle, however expensive, retired with no real replacement in sight … for some very long while … until SpaceX stepped in … kind of sort of). Ah, we also lack good solid RELIABLE nationwide public transit. We literally are terrible at quickly and irreversibly destroying what works (say, public shools and public or non-profit education).
    2. On one hand, yes, great idea.
      Not sure it really is, trying to treat a problem without actually really dealing with the whole problem – the bit that we want is repairable products that will last a suitably long time and targeting just the battery is not really likely to change that very much if at all, as if the point of being obnoxious on the access for replaceable batteries was planned obsolescence as they know they can get away with it and get you to buy another one there are plenty of other ways to get that result.
      And depending on just how much the zealot in the folks interpreting the rules comes out…
      Not to mention the selective nature of actually applying such things to imports as you note.
      1. trying to treat a problem without actually really dealing with the whole problem
        That’s basically all government regulation in general. There’s three competing interests: group A, the consumer advocacy group, tries to lobby for sensible legislation. Group B, the political left usually but not always, tries to tack on extra rules to spite commercial interests and/or create more work for bureaucrats by demands of administrative supervision and intervention, such as by permits, inspections and licensing. Group C, the commercial interests or “capitalists” for short lobby to limit the rules so they become ineffective or impossible to enforce, and/or to extend and modify them so they would hurt their competition worse.
        Group A is the weakest, while groups B and C get along together very well, because C pays B under the table to shut the anti-capitalists up and water down the regulations. B gets to pretend they’re doing something to win votes and C gets to keep doing business as usual with the added bonus of tripping their smaller competitors who cannot afford to abide by the new rules.
        Example: safety and emissions regulations on new cars that are starting to ignore what is even physically possible or statistically meaningful. Combine with “junker laws” on old vehicles, ICE bans, emission zones, etc. that are anti-consumer laws in the end because they force people to scrap perfectly useful vehicles and buy new ones.
        The outcome is ineffective regulation that only undermines group A and the consumers they represent in the end, but group A doesn’t mind since they get to keep fighting the good fight and keep themselves paid doing it.
        That way everyone wins.
        1. Perhaps, but sometimes they do get it right, or at least about as good as you could hope for. For instance getting Apple to use USB-C like everyone else, while I really don’t like USB-C as a standard very much it is THE standard that makes sense for those sort of devices so making it required is just good for everyone (But Apple who now can’t charge you 4x its real market value for the cable). Obviously I’d rather they mandated a more sane standard, but that as would have meant them creating one of suitable capabilities and as anything they created is bound to be worse…
          1. What exactly do you dislike about usb c, other than the generational naming conventions? It seems quite capable both in the power providing and data rate aspects. Maybe could have more longevity though.
          2. @Jdams
            Its a pretty huge list as it just isn’t that elegant ‘universal’ bus any more. The completely invisible difference between a port/cable that can and can’t do all the many ‘optional’ parts of the spec – want a display through your cable, or to provide power, or to have the high data rate, PCIe alt mode neither the port nor the cable needs to be visually identifiable and it will just fail to work, usually silently. USB always used to be plug in and it works at whatever speed the slowest part can do, with the only caveat being if you didn’t have a powered hub or had a power only cable (in both cases it doesn’t work and is rather self diagnosing as nothing else can be wrong).
            Then you have USB-PD that really shouldn’t exist on a new connector – just provide some higher fixed voltages on the connector to allow that higher power transmission, you where adding heaps of pins anyway…
            And thanks to PD you now have USB-C cables with chips in them, making a rubber ducky and a genuine cable rather impossible to tell the difference between non-destructively.
            Then there is complete lack of retention in the ports, personally I like a cable to actually need a little work to remove, especially when if its a full fat does everything USB-C cable its inevitably rather heavy and stiff compared to older specs so actively wants to pull itself out… And the fact that when the port inevitably breaks its just not as easily replaceable as the the barrel jack or older USB ports that can be done with a soldering iron..
            Honestly I can’t think of a single thing I actually like about how USB-C is implemented. Some of the features are great, but the way it gets there not so much.
  6. I have a full set of perfectly good last-generation cordless power tools. When the manufacturer went to the new Li batteries they changed the connector. They do make an adapter ($40 each!) so I went that route and switched to the newer batteries. The new ones aren’t as good as the hold NiCads but mostly I get new ones for Christmas sometimes so it hasn’t yet put me off entirely.
    That said I bought a generic variable power adapter and will harvest an old NiCad pack for the packaging and fab me up a “cordless to corded” adapter that no one seems to make for some reason. It’s in the long ToDo pile on the overflowing workbench.
    1. Indirect coincidence has it, since everyone is chasing after the latest and greatest, NiCads (like the ones needed by the garden solar lights) dropped in price, and now I can find perfectly good ones, larger capacity, that used to sell for premium prices, for not much.
      (compared with 18650s – tho, those, too, have been steadily dropping in price, because everyone seem to be after their larger cousins, 26650 and others).
    1. They should put the cells in a tube right next to the screen, so there would finally be something to grab on a modern smartphone. If it’s shifted towards the back, it would also work as a desk rest to angle the screen towards you in landscape orientation.
    2. I second that.
      I’d want for the phone to have a good Lica-sized lense, with Leica quality. Not cheap imitation, THEE ORIGINAL Leica that had excellent engineering (for its comparably tiny size).
      If they’d flatten 18650s into square bricks no thinner than perhaps 1/2 inch, I’d say the plan is clear.
      Oh, and wraparound screen that shows on both sides, so selfies are just a matter of turning the thing around and voila. Also, return the volume dial, just like the 1980s pocket radios, a volume dial THUMBWHEEL that rotates. Can be hidden, but has to be a thumbwheel.
    1. Have people already forgotten that we once had waterproof smartphones with easily replaceable batteries? I owned one, went through three batteries before finally replacing it, I miss it…
  7. Embedding batteries is not a new thing – it’s been done since the 70s. Especially for devices that were supposed to be portable but power hungry like early calculators. And they’ve been dying just as long. Heck, cordless phones were some of the biggest offenders of embedded batteries where you had to use soldering irons to change them. Or suicide batteries were common in arcade machines. And plenty of devices had coin cells embedded that died after 15 years, some embedded in equipment costing tens to hundreds of thousands of dollars. And once those died your expensive equipment was useless.
    1. Electric shavers… Phillips made one with a lockout that would disable the battery if the NiMH cell was removed. Unfortunately, it would also disable the battery if you left it discharged for too long. I hazard to guess that it kept some battery backed RAM that would zero out if the voltage was lost, and then the SOC would refuse to boot up.
      It would still charge the battery, but do nothing. To get around it, I had to poke a wire at a certain point in the circuit board to latch a transistor on while pressing the power button. Effectively, the only reason a CPU was added to the shaver was to kill the battery. Otherwise it was just a simple linear NiMH charger and a transistor flip flop to turn the little DC motor on and off.
  8. I moved away from expensive wireless headphones. I now use wired headphones with a separate wireless receiver.
    The previous wireless receiver lasted about two years. I now got a new one (ugreen brand).
    I can charge it while I use it. And I could also switch to wired mode if I wanted to. My phone has a 3.5mm jack too.
  9. My stance on this is simple: any component that’s a consumable (gets used up or noticably degrades with normal use) ought to be user replaceable. For a lot of devices, batteries fall into that category. As a personal example, a few years ago a friend gave me his old dashcam which worked perfectly aside from an integrated battery that no longer held any charge. Thankfully it was a simple case of the leads being soldered directly to the PCB so a few minutes clipping those and soldering on a standard JST connector was all it took to make that one user-replaceable.
  10. Honestly I’m hoping the EU will do something so incredibly stupid and bureaucratic that it finally causes markets to decouple from the EU and just refuse to do business there, or else split off a separate company that specializes in that region. EU legislation never achieves its aim, it always just makes the world more irritating and expensive for everybody.
    1. That’s because most people in EU government are actually ex-soviets from East Germany and USSR. Until people rise up and straight out murder them, their children, parents, grandparents etc. nothing will change. I’d love to see blodied skull of Angela Merkel being kicked around like a football by people cheering, eating wurst and drinking beer.
  11. I just hope they can knock this change out of the ball park on this one. It would be cool to get an open standard that companies can contribute to with more open information so those batteries under that standard can be kept in production for a long time. At least for the more flat pack style lithium batteries. I would love to be able to see that happen and we can get other manufacturers creating much larger battery packs that fit the foot print through the lengths and widths of the device, but come with a new cover to support that larger capacity cell and you would just need to punch the details in about it on your phone to make adjustments to accommodate it. I remember my brother had something like I mentioned above for his LG G3 back when my family was all getting unified and used to Android. Coming from the only one out of the 4 of us with a used Apple device before getting a OnePlus 3, it was the most mind opening thing that made me feel more limitless on my phone. But anyways, I hope we can bring back that feature and make that magic happen for some people again.
  12. About the only place I can justify a built-in battery is in devices whose small size will not accomodate the physical overhead of an openable battery compartment, as well as the nonexistence of a small-enough standard battery. This could change with better battery design and more choice.
    Are there people here who actually like NiCds? Unless they’re in a power tool that gets used and recharged constantly, they have terrible life when lightly used, not completely discharged, erratically recharged… normal non-technical user stuff. Good riddance.
    My last cellphone gave me 8 years of service (still works, actually)
Leave a Reply to Sammie GeeCancel reply
