Keep An Eye On Your Air-Cooled Engine
There was a time, long ago, when passenger vehicles used to be much simpler than they are today. There were many downsides of this era, safety chief among them, but there were some perks as well. They were in general cheaper to own and maintain, and plenty could be worked on with simple tools. There’s perhaps no easier car to work on than an air-cooled Volkswagen, either, but for all its simplicity there are a number of modern features owners add to help them with these antiques. [Pegor] has created his own custom engine head temperature monitor for these vehicles.
As one could imagine with an air-cooled engine, keeping an eye on the engine temperature is critical to ensuring their longevity but the original designs omitted this feature. There are some off-the-shelf aftermarket solutions but this custom version has a few extra features that others don’t. It’s based on a ATMega32u4 microcontroller and will work with any K-type thermocouple, and thanks to its open nature can use a wide array of displays. [Pegor] chose one to blend in with the rest of the instrumentation on this classic VW. The largest issue that needed to be sorted out was around grounding, but a DC-DC converter created an isolated power supply for the microcontroller, allowing the thermocouple to be bonded to the grounded engine without disrupting operation of the microcontroller.
The finished product looks excellent and does indeed blend in to the dashboard more than the off-the-shelf temperature monitor that was in use before. The only thing that is planned for future versions is a way to automatically dim the display when the headlights are on, as [Pegor] finds it a little bright at night. We also enjoy seeing anything that helps these antiques stay on the road more reliably as their modern descendants don’t have any of the charm or engineering of these classics.
16 thoughts on “Keep An Eye On Your Air-Cooled Engine
  1. Very strange.
    For the Trabant and the air-cooled Robur trucks manufactured in the GDR, no temperature monitoring was necessary. Read small cars, trucks I dover personally many years.
    The design was safe, so there was no need for fear.
      1. Because they didn’t have enough power to get too hot.
        And if for some reason they did, and you managed to seize up the engine, it was a two-stroke motorcycle engine that was cheap enough to replace. Though chances are someone would just open it up, bang the piston loose with a block of wood, and off you went again, trailing blue smoke.
  2. Does he know the critical cylinder on his VW engine?
    IIRC it’s left front that always burned exhaust valves…That’s where you want the temp sender.
    I’d double check that, been ages.
    I did bugs when they were super cheap, fun cars, not so much fashion accessories.
    Modern ‘bug enthusiasts’ get angry when I talk about the number of German bugs I cut into Bajas.
    They seem to think a Wolfburg was something special…
    I don’t really like the digital dash.
    Should have gone with something period correct if he wanted to keep the value.
    Hopefully easy to remove.
    1. Cylinder #3 is the hot one since it sits offset out of the stream of air. That’s why down the middle fan shroud conversions are nice if you can find them though pricey. I love putting T4 oil coolers on T1 engines and modifying the doghouse to fit. It makes a big difference on the oil temps.
    2. “I did bugs when they were super cheap, fun cars, not so much fashion accessories.”
      Cool. HaD is making me start to want one. For the repairability and hackability, not the fashion accessory. That aspect makes me NOT want one.
      “I don’t really like the digital dash.
      Should have gone with something period correct if he wanted to keep the value.”
      So… it IS a fashion accessory then. Just… a retro one.
  3. Fixing up my old moped, I used a cracked thermocouple temperature gauge from a small aircraft. Cost fifteen bucks plus five for the 100 pack of clear discs, one of which I sanded down to glue in place of the cracked stock one. Works just fine. An exhaust has temp gauge would be better (especially on a two stroke), but this is fine for now.
Leave a Reply to HaHaCancel reply
