Shoot Instax Film In A Polaroid Camera With The Aid Of Tape
Polaroid cameras have been very popular for a very long time and are especially hot gifts this year. Fresh film is easy to find but relatively expensive. In contrast, Fuji’s Instax line of instant film and cameras aren’t as well established, but the film is easy to find and cheap. You might like to shoot cheap Instax film in your Polaroid camera. Thankfully, [Nick LoPresti] figured out how to do just that.
You can’t just slam an Instax cassette in an old Polaroid camera and expect it to work. The films are completely different sizes, and there’s no way they will feed properly through the camera’s mechanisms at all. Instead, you have to get manual about things. [Nick] starts by explaining the process of removing Instax film sheets from a cassette, which must be done without exposure to light if you want the film to remain useful. Then, if you know what you’re doing, you can tape it in place behind the lens of an old-school Polaroid camera, and expose it as you would any other shot. The chemistry is close enough that you’ll have a fair chance of getting something with passable exposure.
Once exposed, you have to develop the film. Normally, a Polaroid camera achieves this by squeezing the film sheet out through rollers to release the developer and start the process. Without being able to rely on the camera’s autofeed system, you need to find an alternative way to squeeze out the chemicals and get the image to develop. [Nick] recommends a simple kitchen rolling pin, while noting that you might struggle with some uneven chemical spread across the sheet. Ultimately, it’s a fussy hack, but it does work. It might only be worthwhile if you’ve got lots of Instax film kicking around and no other way to shoot it.
Instant cameras can seem a little arcane, but they’re actually quite simple to understand once you know how they’re built. You can even 3D print one from scratch if you’re so inclined. Video after the break.
5 thoughts on “Shoot Instax Film In A Polaroid Camera With The Aid Of Tape
  1. “It might only be worthwhile if you’ve got lots of Instax film kicking around and no other way to shoot it.”
    As one does. Lotta darkbox work here. Just buy a goshdarn camera.
  2. Unless you were using a Polaroid camera designed for the earlier peel apart film or for that matter, a medium or large format, regular film camera, the Instax image will be a reversed, i.e. mirror image with backwards text, etc.
    This is because Polaroid SX 70 film is exposed through the front, but Fuji Instax film is exposed through the back.
    I would think you would get better results with less hassle from a roll film camera. A sheet film camera would be even easier.
  3. DIY at its finest: when the only thing standing between you and a working photo is a strip of gaffer tape and a kitchen rolling pin. Love that Nick proved the chemistry is forgiving enough to survive a format transplant—definitely trying this the next time I find a half-pack of Instax at the bottom of a camera bag and an old 600-series staring at me from the shelf.
Leave a Reply to Antron ArgaivCancel reply
