How To Build Good Contact Mics
We’re most familiar with sound as vibrations that travel through the atmosphere around us. However, sound can also travel through objects, too! If you want to pick it up, you’d do well to start with a contact mic. Thankfully, [The Sound of Machines] has a great primer on how to build one yourself. Check out the video below.
The key to the contact mic is the piezo disc. It’s an element that leverages the piezoelectric effect, converting physical vibration directly into an electrical signal. You can get them in various sizes; smaller ones fit into tight spaces, while larger ones perform better across a wider frequency range.
[The Sound of Machines] explains how to take these simple piezo discs and solder them up with connectors and shielded wire to make them into practical microphones you can use in the field. The video goes down to the bare basics, so even if you’re totally new to electronics, you should be able to follow along. It also covers how to switch up the design to use two piezo discs to deliver a balanced signal over an XLR connector, which can significantly reduce noise.
There’s even a quick exploration of creative techniques, such as building contact mics with things like bendable arms or suction cups to make them easier to mount wherever you need them. A follow-up explores the benefits of active amplification. The demos in the video are great, too. We hear the sound of contact mics immersed in boiling water, pressed up against cracking spaghetti, and even dunked in a pool. It’s all top stuff.
These contact mics are great for all kinds of stuff, from recording foley sounds to building reverb machines out of trash cans and lamps.
13 thoughts on “How To Build Good Contact Mics
  1. Note that using more than one element will introduce directionality due to speed of sound and phase effects; this is how pickup patterns other than omnidirectional are achieved. The better solution, if that isn’t what you want, is an unbalanced to balanced conversion, either active or a transformer.
    In stage terms, that’s a DI (Direct Input) box or balun.
    (Part-time amateur live sound engineer, mostly folk – adjacent styles.)
    1. Oh, I hadn’t thought of that, but of course that would be directional. That is what I want, actually what I really want is to sense xyz vibrations in a solid. Three points on a plane and some timing should do it right?
      If any one is curious, or if it’s a solved problem, what I want to do is sense the direction a plucked guitar string is vibrating in.
      1. Direction on a 2 dimensional plane? I think it might be possible to measure the rarefaction at the first instance of the sound and compare the peak and trough, obviously it would diminish over time which is why you need a way to discern when it’s actually plucked. If it’s 3 dimensional you’d need an array of mics on each plane.
        As a matter of interest, Why, what’s it going to be used for?
  2. The video is bad on many levels. For starters the metal disc isn’t copper but brass, then it skips mentioning impedance which is extremely important as those are piezoelectric transducers and most amplifiers and their inputs are designed for mic/line level signals with quite low impedance, then it uses a completely unnecessary dual mic arrangement when it could simply use one transducer wired between the two hot wires of the balanced cable, then properly connect the ground braid, that is, not connecting it at all on the transducer but leaving it connected on the plug, so it would short any noise to the amp/mixer ground. Then it fails to mention that for a contact mic to properly work, it needs a counterpoise to build some inertial mass that counters the vibrations transmitted on the other side of the piezoelectric material. Just glue a small weight on the side that isn’t in contact with the object; that would increase the output by a big margin.
    1. That last thing was just one of the things I realized I didn’t know enough about when I set out to put a piezo pickup to my one-string bass. And not just that, but also acoustic impedance, which is every bit as important as electrical impedance when it comes to converting physical vibration into an electrical signal. But when I saw how slowly this was going, I realized that these considerations wouldn’t show up until at least video #5, if ever.
  3. There’s a whole industry wrapped around mechanical analysis and failure prediction with this sort of thing. For just messing around, the VLC app has spectral analysis features to play with – it can be remarkably handy (“Is that piston slap or a stuck lifter I’m hearing?).
  4. In exploring steel string a instrument with the e-bow concept I made form scratch I went down the rabbit hole of piezo as a pickup. I had a disc under a centimeter high bridge on a long stick of maple. The higher I tuned the more pressure was on the piezo and the tone became like a low cut being lowered. At the lower tuning strengths the tone was rather tinny and weaker. Since gain changes in the feedback loop affected the sustain this would not do.
    Then I realized pressure had the piezo in a more linear region and a piezo just sitting glued to a soundboard etc. has a very tinny sound and is low cut by the series capacitance and makes more of a half-wave sound. I tuned up high and hooked a horn speaker with a transformer to the piezo and got loud audio sans amp! Tune down much less sound.
    Feed AC into a piezo it comes out through a full phase. Acoustic or mechanical vibrations tend to act on it’s at rest state in rectifying way.
    I switched to a small electret mic the size of a pencil eraser buried in the bridge. Much better sound and no sensitivity to pressure from tuning. Power to the mic is no problem there is a preamp, finger volume, processor, power amp, and speaker all on lithium power. Portable Pink Floyd.
Leave a Reply to BrightBlueJimCancel reply
