SNES Controllers Are (Almost) SPI-Compatible
Considering that the Serial Peripheral Interface bus semi-standard has been around since the early 1980s, it’s perhaps not that shocking that the controllers of the Super Nintendo Entertainment System (SNES) would take at least some strong design hints for the used protocol. This does however raise the question of exactly how compatible a SNES controller is when connected to the SPI master peripheral of any random MCU. Recently [James Sharman] set out to answer this question decisively.
The impetus for answering this question came after [James] designed a separate SNES controller board for his homebrew computer system, which led to many comments on that video saying that he could just have hooked the controller up to the SPI board in said homebrew system.
Here the short answer is that the SNES controller protocol is very close to SPI Mode-1, with a similar arrangement of clock/data/chip select (latch) lines and clocking. If you think of the SNES controller as an SPI device with just a MISO line, you’re basically there already. The only niggle that popped up was that the ‘MISO’ line does not get pulled into a high-impedance state when the active-low latch connection is pulled high.
This was fixable by introducing a 74HC125 tri-state buffer IC, after which both the original SD card and twin SNES controllers could be used simultaneously.
10 thoughts on “SNES Controllers Are (Almost) SPI-Compatible
  1. Why have you removed comments of people who told you not to repost common YouTube videos? (As in case of BigClive’s WAGO connectors.)
    1. Perhaps it was a useless comment in a usefull article for the community. I’m kind of humbled about the common quality for the amount of articles and comments posted. I’d applause the moderators
  2. The PSX and PS2 controllers are as well! I wrote a library for AVRs back in the day to read PS1 and PS2 controllers keypad inputs
  3. Whoa, you can really see the old plastic yellowing of the controller on a left (an original) and the modern reproduction on the right. Thanks for the link Maya!
  4. On my endi it says 4 comments, but I see only 2.
    This is anazing, didn’t know this whole time. Need to dig into Mode 1 and see what’s up there.
Leave a Reply to JamesCancel reply
