Modern-day receivers are miracles of digital audio and video processing, but compared to their more analog brethren, they can come with a host of new and fascinating faults. The Onkyo TX-SA806 and SR806 receivers were released back in 2008, with [Tony359] recently getting the latter variant in for repair. Described as having weird digital distortion on the audio outputs, this particular issue got fixed by recapping the PCB with all the digital processing in the first video on this receiver, but this left the second issue unaddressed of a persistent hum, which is the topic of the second video on this repair.
With the easy fix of recapping of the digital board already tried, next was a deep-dive into the receiver’s schematics to figure out where this low-frequency hum was coming from. With it sounding very much like mains frequency hum bleeding through, this was the starting point. Presumably somewhere on the power rails the normal filtering had broken down, so all rails had to be identified and checked for this interference.
With ripple on the 10V and 12V rails as well as the others seemingly in order, it wasn’t clear where the 100 Hz hum was coming from, but people on the BadCaps forum offered some help. After some back and forth it was deduced that the problem was the +15 VA rail, with heavy ripple on it due to a dead capacitor on the +22 V rail that comes straight from a transformer.
For some reason Onkyo’s engineer and/or bean counters had decided that installing an 85°C electrolytic capacitor on the opposite PCB side of a bridge rectifier was a genius idea, which turned out to be not quite the case. With the capacitor eventually giving up on life, the mains hum was allowed to freely pass onto the analog voltage rail and from there into the outputs.
Of course, getting to the target C5662 capacitor was anything but easy, as these modern receivers are tightly packed sandwiches of PCBs, requiring basically a full disassembly. Upon getting to C5662 it was clear that the capacitor was bad, being visibly bulged. Despite being a quality Japanese Nichicon capacitor, such an abusive environment was simply too much. With more similarly poorly spec’ed capacitors at risk of the same fate, these were all replaced with 105°C rated electrolytics.
Perhaps unsurprisingly this fixed the mains hum on the outputs, returning this receiver back to full functionality. In some ways it’s good to know that even with these modern receivers the most typical fault is still due to electrolytic capacitors.
This seems like an excellent argument for the modularization of equipment that performs sophisticated tasks.
Interesting video.
I have a genuine question about ripple measurements. By using an oscilloscope probe with the long clipable ground lead, don’t you create like an antenna that picks up RF noise? I think i’ve read somewhere you should use the kind of spring you put directly around probe tips.
Same, when he is measuring ripple at 8:12 he has clipped a test lead, which happens to be just above a 125V fuse. I would think it is an even bigger RF noise source, so worsening the ripple measurement, am i wrong?
Asked differrently, what would be the best procedure for such measuments?
Also, to remove some capacitor, he had to remove some silicon like substance which i think is here to prevent vibrations. Or is it for other need? Anyway, wouldn’t it have been better to re-use the same type of silicon paste (acetic acid free type i think)? What could be the consequences of not using it?
And at 23:51, he says that Panasonic FR are the best you can get, and i was wondering why.
I’ve found this thread, and it seems that it is true for a SMPS, but not really for audio devices: https://www.eevblog.com/forum/repair/availability-of-panasonic-fr-caps/
True, but we are dealing with audio frequencies here so that’s not a concern on this specific case.
Yes, you want to keep leads to the test point and ground reference short, close together, and away from large noise sources. However, he’s measuring large signals with a fixed, low frequency waveform. It’s easy to distinguish power supply ripple from interference in this case.
Silicone, not silicon. The purpose is mechanical; in addition to vibration damping, it’s probably there to prevent the capacitor from being ripped out of the PCB during rough shipping. It might also help keep the capacitor in place during assembly.
