Large language models (LLMs) aren’t actually giant computer brains. Instead, they are massive vector spaces in which the probabilities of tokens occurring in a specific order is encoded. Billions of parameters, times N bits per parameter, equals N-billion bits of storage required for a full model. Since increasing the number of parameters makes the models appear smarter, correspondingly the size of these models and their associated caches has been increasing rapidly.
Vector quantization (VQ) is a method that can compress the vectors calculated during inference to take up less space without significant loss of data. Google’s recently published pre-print paper on TurboQuant covers an LLM-oriented VQ algorithm that’s claimed to provide up to a 6x compression level with no negative impact on inference times.
The tokens aren’t directly encoded in the vector space, but their associated key value is, which along with the single token per inference process creates the need for a key-value (KV) cache, the size of which scales with the size of the model. Thus by compressing the KV cache using VQ, it will reduce its size and correspondingly speed up look-ups due to the smaller size in memory. One catch here is that VQ is due to the nature of quantization some accuracy will be lost. The trick here is thus to apply VQ in such a way that it does not affect this accuracy in a noticeable manner.
Other aspects that had to be taken into account by the TurboQuant algorithm was fast computation to keep up with real-time requirements, along with compatibility with so-called ‘AI accelerator’ hardware.
Key-Value Cache
A basic way to look at the KV cache in LLMs is that it caches the results of previous inference cycles. An in-depth explanation can for example be found in this article by Sebastian Raschka. In the case of generating a phrase of three words starting with the word ‘Time’, we can see the following repeated computations:
Considering that inference is rather expensive computation-wise, you really want to cache these calculated values. This provides a massive boost in performance and much lower CPU load, but because there’s no such thing as a free lunch the catch here is a rapidly increasing memory usage.
Correspondingly, we now have a big in-memory cache to manage, along with memory management routines to make sure that the KV cache doesn’t exceed its allocated memory pool:
As covered in a December 2025 NVIDIA Developer article, KV cache optimization has been a topic for a while, with the article in question covering NVFP4. This is a VQ approach that reduces the precision of the KV cache from 16-bit floating point to 4-bit (FP4). Meanwhile production systems already employ 8-bit quantization, also using a floating point format (FP8).
An additional cost here is that FP4 has to be dequantized back to FP8, which would seem to be an implementation detail in the current version. Compared to FP8 quantization, FP4 reduces latency by up to 3 times and halves the required memory required, while accuracy is negatively impacted by ‘less than’ 1% compared to FP8 due to quantization error.
Accuracy here is important as it factors into the next auto-complete step when the LLM’s probability vector space is once again rummaged through for the next statistically most likely follow-up token. KV cache VQ compression is thus always a trade-off between memory use and accuracy. In short, the same issues apply as with all implementations of quantization-based compression, including the tragic absence of any free lunch.
Turbo Quantization
So what magic did Google’s intrepid engineers pull off to improve on NVIDIA’s NVFP4 approach? The key is in how the quantization is performed, as it isn’t simple a matter of truncating or throwing away data, rounding up to the nearest available value. Instead a series of steps are applied that seek to minimize the quantization error, which in the case of TurboQuant is (confusingly) an algorithm called PolarQuant followed by the QJL (quantized Johnson-Lindenstrauss) algorithm.
Annoyingly for the non-mathematically gifted/educated among us, Google didn’t simply provide a straightforward visualization like that for NVFP4 that’s understandable even for us software developers and other casuals. For NVIDIA’s format we can see that it takes the form of a single sign bit, two exponents and one mantissa (E2M1), as well as a shared FP8 scale per block of 16 values.
One step where TurboQuant appears to be differ is in the PolarQuant algorithm, that applies a polar coordinates transformation to the vectors, following which a typical normalization can apparently be skipped.
This polar transformation is preceded by the application of a random projection matrix as a type of preconditioning that will affect later normal distribution, with proof and the full algorithm provided in the PolarQuant arXiv paper for those who desire more detail.
Of note is that PolarQuant employs the Johson-Lindenstrauss lemma, which Google researchers used as the basis for a JL-based transform called QJL. From reading the blog post it’s not immediately clear whether QJL is directly integrated into PolarQuant or an additional step, due to the muddled messaging on Google’s end. From the benchmarking results it does appear that QJL is an additional step.
What we know is that the final format that TurboQuant ends up with is three-bit value, which would logically be 1 bit smaller than NVFP4, or an approximate 25% smaller KV cache for the same amount of data.
Judging On Merits
Comparison and benchmark data in the Google blog post and associated papers do not provide direct comparisons with NVFP4, and the few numbers that are thrown out are rather inconsistent, or unspecified. Take the claim of ‘at least 6x smaller memory size’, for example. The blog text does not clearly specify what this is relative to, while it then tosses out a 4-bit TurboQuant number of 8x performance increase compared to FP32.
Although with some more digging and poking of the available data it might be possible to glean some actual performance information from the provided files, it’s rather vexing how vague Google’s messaging is kept. Not to mention the lack of direct benchmarking against what would be the biggest competitors in the space.
It is definitely true that VQ is a thing for LLM KV cache compression, as we have seen, and NVIDIA ‘accelerator cards’ provide hardware acceleration for this feature, so this is the reality that TurboQuant would have to compete with. Based on the few clear facts that we do have it doesn’t appear that it’s quite the revolution that the hype machine has made it out to be, with it likely being just a bump over NVFP4 that NVIDIA is likely to trump again with its next quantized format.
It will of course be most interesting to see how this will play out once TurboQuant makes its way out of the laboratory into the wider world and we start seeing independent benchmarking performed.
Hi,
“Vector quantization (VQ) is a new method that can compress …”
Vector Quantization actually exists for as long as computers. It’s been extensively used, for instance in image compression.
I think the late 90’s early 2000’s “RealPlayer” compression algorithm used VQ.
There was a TwinVQ audio codec in the early 2000s, some parts of which were rolled into MPEG-4 AAC.
Yeah, I didn’t make that claim in the original draft. I’m not sure why that was changed during editing.
The LLM editor added that, eh? :-)
This is the problem with LLMs in a nutshell. They do not understand what they are working with. They are nothing more than a text generator using statistics about a very large body of texts.
There is nothing in a LLM that encodes knowledge or logic. All it does is to consult its statistics to pick the next token.
That the result resembles a text written by a person is amazing, but there’s no intelligence involved. Facts and knowledge do not exist in the statistics.
The models are literally able to extract underlying concepts from the data. This is well documented and known.
https://en.wikipedia.org/wiki/Grokking_(machine_learning)
Look, it’s clear that their brain doesn’t understand what they’re working with. There’s nothing in it that encodes knowledge or logic. :D
Read your own link. That is a discussion of training neural networks for specific tasks. It is not about large language models.
Non-sequitur.
The “concept” behind some training data can be represented by multiple different models, some of which “overfit” the data and produce results that replicate it but do not generalize correctly. As the training progresses, better and better models are found that do generalize and are able to predict the hold-out set which is not part of the training. This “grokking” is basically the algorithm eventually converging on a style of solutions that fit the problem, but it doesn’t mean it is the correct solution, or what was meant by the data.
It’s like the computer doing the block bucket test, and randomly figuring out that you can simply flip the lid open and drop the blocks in, and it generalizes for all shapes of blocks. Yeah, that’s one way to solve the problem…
https://arxiv.org/pdf/2506.12027 they can in fact be turing complete.
When can I expect a tamagochi form factor device with LLM brain and speech capabilities to talk to me about weather and tell me it loves me 10 times a day?
Well, first it isn’t a ‘brain’, just a statistical text generator, but I am sure something is thinking about a tamogochi device — for therapy purposes of course ;) . Of course you’ll have to pay for the service, so the device can call home and get fresh goo to spew.
The algorithm:
Assume you have a vector in multiple dimensions, several of which are close to zero. You want to save space by reducing precision, but reducing precision in the dimensions close to zero makes them zero: a coordinate value of .0000000032 will become zero.
The solution is to pick a random rotation and rotate the original vector. This brings all the close-to-zero coordinates up to something closer to one, and all the close-to-max coordinates down.
Then you chop off bits to reduce precision.
When you want to use the vector (as inner product with another vector), you don’t need to unrotate it: apply the same rotation to the input and then calculate the inner product: You’ve rotated both vectors the same, so the inner product will be the same.
Doing the random rotation allows you to reduce precision, saving lots of KV cache memory, while preserving the effects the very small coordinates have.
And as to the reduction of precision, note that the human brain gets by with roughly 3 bits of precision in its input channels. Light intensity is quantized to 12 possible values, you can only distinguish six different sound pitches simultaneously, and so on. (Read this wikipedia article if you disagree with this, it has to do with information channel capacity.)
https://en.wikipedia.org/wiki/The_Magical_Number_Seven,_Plus_or_Minus_Two
Thank you for that explanation. It makes a lot more sense to me than Google’s blog post or the PolarQuant paper did :)
Useful comment of the day, thank you!
Awesome comment, thank you! The math behind all this is fascinating.
If certain components are very small why is it a problem if quantization makes them zero?
Because the differences between their values are still meaningful and carry information, which is lost when they’re rounded up.
It’s like comparing people to the size of the Eiffel Tower and rounding up to the nearest elephant. Yeah, everyone’s going to be “zero elephants” and all the information about the differences between people is lost.
Think of the randomness as akin to dithering a low-bpp image.
If you just snapped every pixel to the nearest available colour value, large areas of subtly different colours will all end up at the same value and detail is lost. Dithering adds randomness that causes the values to jitter around the original, proportionally to how close they are to the quantized value. You trade resolution but gain fidelity.
Every time my eyes see “Turbo Quantization” my brain reads “Turbo Encabulator.”
Same ****, different decade. =))
A bunch of third parties have already implemented turboquant for various toolchains, and there are now multiple reports that QJL doesn’t actually work for KV cache (but does work for basic vector search). Instead, a new technique called V3 is being used to replace it.
Some details and results are in the turboquant-pytorch repo here: https://github.com/tonbistudio/turboquant-pytorch
SOTA AI systems are far more than just a LLM model doing a randomised f(input).
The quality of the comments on LLM articles has really decayed as AI has become less popular. We’ve even got significant numbers of folks back on the LLMs as sentience march again.
Feels a bit like only the AIbro true believers and investors care much anymore.
