Throughout the centuries the art of lock-making and lock-picking have been trapped in a constant struggle, with basic lock designs being replaced by ever more complex ones that seek to thwart any lockpicking attempts, as well as less gentle approaches. When it comes to the very common pin-and-tumbler lock design, the main issue here is that the keyway also provides direct access to the lock’s mechanism. This led [Works By Design] to brainstorm a lock design in which the keyway is hidden.
The ingenious part here is that because the actual key is rotated away after insertion, there is no clear path to the pins. This did require some creative thinking to have a somewhat traditional style key as well as a way to turn the internal mechanism so that the key would be pressed against the pins. Here inspiration was drawn from the switchable magnet mechanism as seen with e.g. magnetic bases. This ensures the key and key handle can be detached and attached quite firmly.
After many 3D printed prototypes, a metal version was CNCed and subjected to some early testing by a locksmith, who even with having seen the CAD model of the lock was stumped. With this initial result and some user feedback in the bag, it was time for large-scale testing with more lockpick enthusiasts, as there are many more ways to open a lock beyond pushing pins. That said, a mechanism was also added to the lock to prevent bumping attacks.
The next testers were found in the Lock Pickers United community, one of whom raised the issue of an impressioning attack. With a couple of test locks on their way to said lockpicking enthusiasts it’ll be exciting to see whether this new lock design will set the standard for future locks or not.
I love this channel, and this lock is very cool as a concept, BUT…More than anything else, a lock in the real world has to be robust. I think this key is not (the magnetic haft is going to get separated and lost), the lock is trivial to destroy by over torquing or putting gun in the slot and rotating it. Again, nothing against this lock. I think it is very cool, but I don’t think it will ever replace more traditional locks.
i think locks are primarily useful for the psychological effect it has on would be criminals. it’s a surprisingly effective way to communicate phrases like “this isnt yours” or “stay out” and placing an inconvenient hunk of steel in your way. of course these are impotent in the presence of a diamond cutoff wheel or a shotgun and a breaching slug, or for the commando types, thermite. still you cannot argue their efficacy as a crime prevention device.
i want to see a lock that maximizes the psychological effects (not absent in a lock such as this mind you). not necessarily the one that would be the hardest to pick, but which makes the picker question reality itself to the point where you come to your shed the next day and find a criminal on the ground in the fetal position crying with lockpicking tools strewn around.
“diamond cutoff wheel or a shotgun and a breaching slug, or for the commando types, thermite. ”
or you know the more practical, swift hard kick, crowbar, or boltcutter solution.
Bolt cutters won’t cut a high quality lock, but a cordless angle grinder will.
“a high quality lock”
which 90%+ of locks people use ARE NOT.
Masterlock Contractors series boron alloy shackle vs 42 inch bolt cutters https://youtu.be/HYJLcA32mv0?si=LIplE96THEyPMwA8&t=129
Shrouded Masterlock with boron alloy shackle
https://youtu.be/TXQOO3RMXNM?si=hvRIhyekEMwvnJWS&t=177
Stanley 24/7 shrouded lock https://youtu.be/qKQYbNNQtBQ?si=hxP1ok-cQJoNdXJS&t=281 hardened molybdenum steel shackle.
You can defeat angle grinder with ceramic spheres encased in a cellular aluminium structure.
https://www.imeche.org/news/news-article/non-cuttable-material-shatters-bullets-and-turns-angle-grinders-back-on-themselves
Swift, hard kick you say?
https://youtu.be/ET9SNXpeORY
Yes, of course there are exceptions. But MOST doors arent a drug kingpins fortified reinforced steel framed monster. Most doors swing open with a well placed kick https://youtu.be/zwij_VG09Ws?si=YCelVmx8x4ZMQEop
simplest idea: smack the lock with any sort of sh.t. Make it smelly. Done.
Caution: If you try to pick this lock, it might pick your sanity instead.
It’s a prototype.
You can readily increase its robustness with replacement materials.
the sad thing is even the most well engineered lock can be defeated in seconds with a bit of thermite.
with the way the internet acts you would think this would happen every 15 minutes. With 2 brother, a father and a grandfather on the force, combiled they have heard exactly ZERO reports of thermite being used in a break in and have never heard another officer who had taken a call involving thermite.
As a welder, I can imagine far more ways applying thermite to a lock would turn it into a chunk of nearly permanent obstruction than being lucky enough to have it OPEN anything.
combiled=combined. Not sure what happened there
This needs to be sent to LockPickingLawyer for analysis.
..what I came here to say. If you haven’t sent one to the LockPickingLawyer you are simply playing games, not trying to make an actual product…
The other thing with mechanical key locks is that it is sort of a solved problem with electronics instead. However, many of those are done really badly too – in reality.
I’m quite sure electronics make it harder to make a secure lock, not easier. It add a few whole extra attack surfaces. Software, electrical and electro-mechanical.
You need to translate the electrical signal into a mechanical one, which is likely the easiest to attack, for example: A solenoid can be bumped and activated with a strong enough external electromagnetic field.
Assa Cliq and Kaba Evolo are completely pickproof. You need the right key bitting and the correct digital code at the same time otherwise thr lock does not open.
Yes! Yes! I was wondering if I was going to have to be the one to post that! Yeah he’s got lock picking skills, ninja skills, MacGyver skills…..
Thank you old masterful one.
Oh masterful one. Not “old” sorry
unless you are old…. the, not sorry : )
A part of me was waiting for the lock smith to cut a section of drinks can and shim the shackle.
Whenever I see a project with a magnet (big or small) I can’t help thinking about the iron particles that are around us everywhere and will cling on to it and never go away…
Very cool, but I suspect in the real world it would be removed just as fast as a far cheaper lock because thieves don’t pick locks, they just smash them, cut them, or lever them apart… or they attack the door/chain the lock is attached to if that’s the softer target… or they just go through a window or knock a hole in the wall…
It would be really interesting to ask the police how many crimes involve locks being picked vs some other method of attack/entry.
This type of lock exists, but I’ve only seen it in very rare safes. The operation is to insert the key completely into a hole, close the cover and open the lock. The key will be returned after the door is locked. The Forever Lock attempted something similar, where their latest iteration is overcomplicated. This is a great prototype demonstrating the concept, and it may stand the scrutiny of the lockpicking community. Mostly as the plastic pin will mash up, and likely result in the lock being inoperable after an impressioning attempt. I would like these locks to be more widely than just influencers. Where several lockpickers, me included, will certainly give it a run for its money. We have decoding strategies which work on very much any lock in a lab setting.
In case you are wondering if it is something new, I have a quote for you:
“Few self-respecting professional “inventors” have felt their mission to be fulfilled until they have “invented” a lock of some kind. Apparently there is a fascination in the subject which they cannot resist, however complete their ignorance of the past achievements and present development of the art, and so each incontinently proceeds to “invent” things which, while new to his untutored mind, are usually already well-known, occasionally in successful use, but more frequently long since consigned to the limbo of useless and discarded schemes.”
—Henry Robinson Towne, Locks and Builders Hardware: A Hand Book for Architects, 1904
