A Hackable Analog Phone System
Do you have old landline phones laying around the house, with touchtone buttons or rotary dials? Perhaps you’d like to do something with them! [Scott Dylewski] has built hardware to let you do just that, since your local utility might have pulled down the lines already.
The Analog Redial is, essentially, a “little phone system you can hack,” according to [Scott]. Plug in a phone or two, and you get the functionality of yesteryear—a dial tone, ringing, and all that. You can make calls between the phones, out via a SIP server, or use the answering machine functionality. You can play around with settings via a web interface, or even set up dial codes so your phone can control your Home Assistant setup.
An ESP32-C6 does all the heavy lifting, with the aid of an ES8388 audio chip, and lets you plug in two phones for telephonic hijinks. You can even add a Bluetooth board to use your old landline as a handset for your modern smartphone. [Scott] has all the files on GitHub if you’d like to make one yourself, and you can get most of it pre-assembled by a board house if that’s your jam. It hardly gets easier than this.
We’ve featured other fun projects that repurpose old phones for new purposes, too. If you’re whipping up telecommunications witchery of your own in the home lab, be sure to notify our tipsline. Happy phonery!
25 thoughts on “A Hackable Analog Phone System”
  1. This is neat and if it is compatible with old school ringers which needs weird voltages (60-90VAC) it could become incredibly awesome.
  2. I’ll have a look at this. I have an on and off project for about 10 years to do exactly this (or let’s say the HFP part for 1 phone of it). I personally am aiming for the ESP (classic) doing the HFP but maybe I’ll should just use this and have it working instead :p
      1. Unfortunately yes. I’m also hoping that at some point we get new ones supporting classic, or, that a widely available and implemented BLE alternative comes to existence
  3. I wonder about combining this with a mesh network to have a decentralised wireless off-grid phone system, where you can just plug in any old landline into a node and have it jump on the network.
    It’s got Bluetooth and assuming that the web interface is probably via WiFi , perhaps this ESP variant also has the SDR capabilities?
  4. This would be a great way to make use of my batphone red Western Electric model 500 and an old (wooden ringer box!) Kellogg desk phone, instead of just using them for display items.
  5. You will love that Carbon Mic Audio. :)
    If you have ever wondered it seems the habit of banging of something to make it work better is properly reinforced with the ownership of carbon microphones.
    1. Which is not a bad thing for a one off project or demonstration! I would like to have a similar setup and with an helpful agent I could just use similar components and make it work
