Finger Joint Cutter Uses A Jigsaw Blade, But Not As We Know It
Around these parts, finger joints (or box joints) are usually the product of laser cutting. [bluesyann] shows us a method of using a stationary jigsaw, a custom blade, and 3D-printed jig to create a DIY box joint cutter whose results look impressive. What’s appealing is not just the end result, but the fact that the whole system is made from little more than an inexpensive tool, scrap wood, and common hardware.
A DIY wide blade cuts each notch in a single go.
In [bluesyann]’s system, the jigsaw is fixed in place to make a stationary cutter. The saw itself is nothing special; it’s the wide blade that makes the difference. It cuts a notch in a single go, and it’s made by epoxying together multiple blades to make a single extra-wide one. Jigsaw blades are not expensive, and they’re easy to snap into pieces. By using a total of three blades (snapping two of them into pieces) one can create the wide version shown here.
With a stationary jigsaw sporting an extra-wide blade that cuts the same notch every time, all that remains is a way to get the spacing right. The solution there is a 3D-printed jig that each freshly-cut notch fits onto as the next one is cut.
There are a few other details, but those are the important bits. One does have to do a bit of trial and error to get things dialed in, but once they are, it’s off to the races.
If one prefers a less hands-on method of cutting box joints, check out this robotic table saw which automates the process.
40 thoughts on “Finger Joint Cutter Uses A Jigsaw Blade, But Not As We Know It”
  1. Well….i guess it’s technically a hack so yea, and I guess it’s safer than the table saw or router. Just the idea though of snapping good blades…
    1. I would prefer the table saw, or the router table. With the appropriate jig, it is faster and safer than this ( no dubious glued blades )
      1. I’d prefer the router. Table saws scare me even when I’m confident in what I’m doing and being very careful about it. A glued blade that moves much more slowly scares me less as well.
  2. There is always something new, but a portable/budget miter saw or a table saw with simple rig accomplishes this (and plenty other things) after some strategic thinking. It gets even simpler with the miter saw, as that’s what they are kind of sort of built for.
    Though, decades ago, I’ve tried this exact thing (cutting finger joint) with ordinary budget cutter and custom-made rig with mostly okay results, as it is quite tricky to get everything right that way. Kudos for those who figured out a better way : ]
    Usually I don’t bother and go the quick and easy route of pre-drilled holes and long screws. Seem to work for me, the numerous shelves, benches, etc (one kitchen table, too) I’ve built over the years don’t seem to budge, but of course, these joints don’t experience much flexing, and most are not visible. The finger joint is much tougher, since it interlocks and can handle flexing, whilst screws-coupled joints eventually pry themselves loose from repeated stress (but then again, that’s why you suppose to reinforce those with strategically placed metal brackets).
    I’d probably advise against doing anything to the blade, as it is already flexing under load quite a great deal. While it is not as dangerous as, say, breaking router bits (you really DO NOT want to test router bits for breaking – don’t I have a story about a cheap router bit going rogue), it is still quite easy to break off at the time the least expected.
    Having rambled all that, I’ve seen people doing amazing things (not me, sadly) with a table saw. I’d still vouch for using a table saw (sadly, I never owned miter saw), but that’s just me.
    1. Are you sure a miter saw is the tool you’re thinking of? I can’t begin to imagine a way to use a miter saw to cut box joints, let alone safely. Nor its scarier precursor, the radial arm saw.
      Maybe a router table, if you don’t have the space for a table saw, though I think the table saw is safer.
      1. Table saw, you rotate/move the piece you are cutting, the blade/saw is stationary; miter saw, you rotate/move the blade, while the piece is stationary. The finger joint jig will be similar for both.
        IMHO, I’d prefer portable miter saws for things like this, alas, maybe it is time I invest into one, since I come across similar tasks quite often. Oh, I’ve also seen people doing wonders (not youtube, not imaginary friends, sadly, not me either) with nothing but a table saw, cutting the jig, etc. Miter saw is easier because the angles can be measured very nicely, and some come with the laser helping with cutting (table saws, emm, probably no, where would one mount the laser – on the piece being cut : – ???).
        Finger joints actually look aesthetically pleasing to the eye, and basically permanent once glued. I prefer screws for a different reason, sometimes I don’t want to keep the thing around (book shelves, ie) and rather have the Plan B of reusing parts elsewhere : ] (on a different note, 6+ years ago we built a gazebo in our backyard, obviously, with deck screws, because eventually we’d want to be able to take it down like a lego house).
        1. Can you please elaborate more on how you’d make a box joint jig with a miter saw? I can’t imagine a way to do so without removing the table.
          1. Miter saw. The one with the built-in rig/table that holds the piece being cut.
            Circular saw, yes, I own one, but it is used for what it is really good for, mostly rough cuts (or long cuts along really really long boards that won’t cut well with a table saw). I won’t plan finger joints cutting with it, too much headache.
      2. I actually 100% agree that the router table and two bits, straight and trapezoid one, would be easier for cutting finger joints. The simple/obvious jig would be the plank the width of the joint cut into the number of steps.
  3. I bet once the jig is set up right, it’s great for a few cuts like an occasional drawer corner. This would be great for someone who already owns a jigsaw, with limited shop space and budget. I could have used this when I was young and the table saw and router were off limits for safety reasons.
    But I’ve found that jig saw cuts are kinda inherently sloppy, even with a steady hand, good tool, blade, and a straightedge. You’d also likely have to cut pretty slowly so the blades can eject the wood chips and not fill up.
    Much better than drawing out each one with a square and multiple passes with a single jigsaw blade though!
  4. can’t believe no one here wants to brag about knowing the word ‘dado’
    i hate it but there’s no denying that making a dado set out of a reciprocating saw is a hack!
    1. Why would anyone, dado’s are incredibly dangerous and thus forbidden in the EU for table saws. Having one is considered stupid and dumb. There are far safer options for the same result. However I can appreciate the hack from this article
      1. Then maybe the EU should teach people to not try to stop rotating blades with their fingers ….
        A tool properly operated and properly respected is not dangerous. People who are lazy and do not want to learn the correct way to use tools are the real problem, and the ones that should be forbidden to mess with things.
        1. A tool properly operated and properly respected is not dangerous.
          But even the best trained people are not infallible and accidents happen. Lots of machinery regulation is written in blood.
          1. My respect for power tools is written in my own blood. Yes, a dado was involved.
            (Yes, I still have all my fingers, but it was a close call)
  5. Wide wooden popsicle sticks make great joiners if you have a saw blade of the same thickness. After glueing and clamping 24H they can easily be sanded flush with a belt sander.
    1. Nah I doubt there’s any risk worth worrying about here, it’s reciprocating, they aren’t going to fly off with any significant force.
  6. Great idea! The one question I have is how long that blade will last before snapping. As mentioned by the author, saw blades are brittle, and the single tang supporting the center is taking the stress of five blades cutting into the wood.
    Perhaps the saw blade holder could be modified to take multiple-width tangs?
  7. How long does the epoxy hold up? There is friction, thus heat, involved. I wonder if silver soldering (or welding )the sawblades together would be a better approach.
    1. You both make good points here. My suggestion is a spot welder. You can build one with a microwave transformer. Once you swap out the coils, they’re not nearly as dangerous.
    2. The wood will start burning before the epoxy fails.
      I was once quite annoyed at discovering two-part epoxy didn’t fail at around boiling water temperatures like most adhesives do. Damned stuff still held up in the oven at much higher temps for quite some time.
  8. colour me skeptical, but there seems to be way less tear-out on those joints than you’d get with a jigsaw. Plywood like that will tear and splinter if you look at it too harshly
    1. not to mention, the bottom of those cuts are way to flat and even. Those jigsaw blades are going to cut a slot with a ‘ww’ shaped bottom
  9. This seems like an inordinately complex way of generating a dado/finger joint, usually done on a circular saw with a specialty stacked blade set (the impossibly neat bases of the cuts have been mentioned by others). If one must persist with a jigsaw, brazing the stack rather than epoxy would seem to be a good idea and if done correctly shouldn’t weaken the blade teeth’s tempering.
    1. I am interested in how you think this should be accomplished without messing up the temper. It’s a very thin piece of metal in both dimensions.
  10. Some folks are talking about the blades , I’m thinking the extra resistance will find the weak component of the jigsaw … with magic blue smoke as a bonus.
  11. To be honest, the 3d printed adjustable finger annoys me. It is trivial to make it out of wood with all the precision.
    Anyway, it’s an approachable design. I’ve seen lots of other box joint setups.
    jigsaw https://youtu.be/V7IARE2GbXA?si=FcpJdiSEUL7AZitI
    miter saw https://youtu.be/Do0p9BxcXc0?si=1ABpM3DgbG-EPaF9 and https://youtu.be/WSsBCCgd7mw?si=wCwM40eCaXANGai9
    There are lots on table saws and the same on router tables. There are others for hand held routers.
    You can hand cut box joints, but any mistake is hard to hide. Hand cut dovetails are more forgiving and stronger.
