[Morley Kert] had a problem. He’s a big fan of the lovely Fortune Chair from Heller Furniture. Only, he didn’t want to pay $1,175 for a real one. The solution? He printed his own instead!
The basic concept is simple. Capture or recreate the geometry of the fancy expensive designer chair, and then print it out on a 3D printer. That would be easy, except for scale. Chairs have to be both big enough to seat humans, and strong enough to carry their weight. For the average 3D printer owner, meeting the big requirement is difficult, since most printers are quite small compared to chairs.
[Morley] gets around this in the typical fashion—he prints the chair in multiple segments. Indeed, we’ve seen [Morley] tackle a similar project before, too. Only, last time, he had the benefit of a print farm and some easily-accessible geometry for the target object. This time, he’s working very much more from scratch, and chose to print everything at home. That made things quite a bit harder.
Scaling up is never as easy at it seems at first!
Continue reading “You Wouldn’t Download A Chair…But You Could”
