The more tools you have the better. Unfortunately, not everyone has the space, or the money for full-size equipment. Looking to expand his maker capabilities, [Bruno] had the clever idea to turn a hand-tool, into a power tool. One we’ve never even seen before — a powered hacksaw.
Using his 3D printer he designed a linkage system, not unlike a steam locomotive drive to turn rotary motion from a geared motor into linear motion. Not only that, it also angles the hacksaw as it goes. 3D printed brackets hold the hacksaw in place, and weight can be added to the top to adjust the cutting speed. He even 3D printed a guide for his vice to line up the material to where the blade will cut.
It’s a bit slow, but it’s fantastic at making cuts! Continue reading “3D Printed Linkage Produces Automatic Hacksaw!”
