Originally Android apps were only developed in Java, targeting the Dalvik Java Virtual Machine (JVM) and its associated environment. Compared to platforms like iOS with Objective-C, which is just C with Smalltalk uncomfortably crammed into it, an obvious problem here is that any JVM will significantly cripple performance, both due to a lack of direct hardware access and the garbage-collector that makes real-time applications such as games effectively impossible. There is also the issue that there is a lot more existing code written in languages like C and C++, with not a lot of enthusiasm among companies for porting existing codebases to Java, or the mostly Android-specific Kotlin.
The solution here was the Native Development Kit (NDK), which was introduced in 2009 and provides a sandboxed environment that native binaries can run in. The limitations here are mostly due to many standard APIs from a GNU/Linux or BSD environment not being present in Android/Linux, along with the use of the minimalistic Bionic C library and APIs that require a detour via the JVM rather than having it available via the NDK.
Despite these issues, using the NDK can still save a lot of time and allows for the sharing of mostly the same codebase between Android, desktop Linux, BSD and Windows.
Continue reading “Going Native With Android’s Native Development Kit”
