Twin jet engines mounted on tank treads
Big Wind Is The Meanest Firefighting Tank You Ever Saw
As the Iraqi army retreated at the end of the first Gulf War, they took the term “scorched Earth policy” quite literally. Kuwaiti oil wells were set alight en masse, creating towering infernos that blackened the sky.
As it turns out, extinguishing a burning oil well is no easy feat. In the face of this environmental disaster, however, a firefighting team from Hungary made a name for themselves out on the desert sands, astride a jet-engined tank named Big Wind.
Continue reading “Big Wind Is The Meanest Firefighting Tank You Ever Saw”
