[ghostwalker] has put together instructions for running X11 on your Android device. This means you can run a full-blown Linux desktop environment on your phone. It requires you to already have a Debian shell on the phone, which we covered earlier. Instead of having to come up with a custom display driver, it’s hooked to a VNC server. You can connect to it using an Android VNC viewer on the phone or via any other VNC client. The how-to suggests either IceWM or the even lighter-weight LXDE for a window manager. You could potentially install Gnome or KDE, but we’d be surprised if it was any faster than dog slow. Let us know if you have any success with this and what you think the best use is.
