This mind boggling piece of art took hundreds of hours to make over a period of three years. The entire structure is composed of thousands of components, all of which are part of the clocks circuit. They call it, The Clock.
Each component was hand soldered in this ridiculously complex 3D structure. They have a typical artist statement, but you know what — for once it’s actually pretty intuitive.
“The Clock” has digital pulses flowing inside every single wire and every single part. These synchronized pulses, all intelligently controlled and channeled through every circuit, is a binary “dance” of hundreds of bits of information coming and going from one section to another. All working in unison to display the flow of time.
The clock works by taking in mains voltage and counting the frequency of pulses — in North America it’s 60Hz — conveniently a unit divisible for time. However if you were to take this clock elsewhere, perhaps where AC cycles at only 50Hz — the clock’s not going to keep accurate time.
It has no buttons — but you can change the time using a “Time Adjusting Magnet” over certain areas of the clock which feature micro electro-magnetic switches. The whole thing weighs about 14 pounds and consists of 1,916 individual components! Wow.
This has gotta be up there with some of our favorite clock builds we’ve ever seen on Hack a Day, perhaps with it only being second to this home-made Atomic Clock!
[Thanks Arthur!]
