There’s a lot of talk about CAD software these days, and don’t get us wrong, they’re an essential tool of the trade. But for roughing out an idea, nothing tops paper and a pencil. Even the back of a cocktail napkin will do.
If you’re like us, at some point you may have had an engineering teacher force you to sketch your ideas out on paper, rather than in software. Or maybe you went to a university that required engineering students take a drawing/drafting class, where the first few weeks, you’re only allowed to use paper and pencil.
It may seem silly that in today’s age that one would choose to sketch an idea out by hand, but one simple drawing can communicate an idea quickly and easily – and that’s key. After all, the biggest part of engineering is communication.
If you’re a bit older you may remember a staple in every engineering office was the green graph paper – some people called it an “Engineer’s Notepad.” It’s basically perfect for jotting down an idea. Thick lined graph paper on the back of each page that lets the lines be visible on the front, without being distracting. It’s becoming harder and harder to find at your local office supply place, but if you search for “Ampad Engineering Pad” you’ll still find it. (There is also a “National” brand that this writer prefers.)
If you’re in a pinch, or don’t want to pay for a full pad, we found a wonderful alternative. This online graph paper generator will allow you to make your own graph paper, and even customize it to suit your needs. With things like multi-weight lines, and polar graphs and much more. The result is a PDF file you can download and keep for the future. Or if you’re a bit crafty, you can add your own logo in an vector-type editing program such as Inkscape for free.
Still need some pointers on how to using this for project planning? [Steve] sets the standard for graph-paper project planning.
