When you’re hunting zombies you’ve got to give them something to fear. [Shannon Larratt] is getting ready for that eventuality by adding devil horns as his hood ornament. It looks awesome from afar, but when you see the close-up images you realize how lifelike this is. That’s because it’s not a sculpture. [Shannon] cast the ornament in a mold made from his own hand.
The process started with some dental alginate which he slobbered all over his hand as he held the devil horns pose. After the mold had hardened he cast the ornament using fast-curing black plastic resin.
With the ornament now in hand he needed a way to secure it to the hood of his vehicle. He picked up a threaded U-bolt. A hole and a slot were carved in the base of the ornament to receive the U-bold and a straight bolt for a trio of anchor points. More of the black resin fills the holes, securing the bolts and making it a snap to mount the ornament by drilling through the hood.
We also find it awesome that during this process [Shannon] took the time to cast his daughter’s fist for use as a door knob at home.
