Nuclear Waste Remediation By Proton Beam
One of the issues with nuclear power plants is that they produce long-lived radioactive waste. Storing spent nuclear fuel is a real problem. However, researchers at the Department of Energy’s Thomas Jefferson National Accelerator Facility have made strides not only to produce more electricity from spent fuel but also to break it down into shorter-lived nuclear waste. [Aman Tripathi] shares the details about NEWTON, a program to fire high-energy protons at a target to produce a flood of neutrons that can interact with nuclear waste. You can read the original press release, too.
Short-lived, of course, is a relative term. Unprocessed spent fuel may be dangerous for about 100,000 years. After the proposed processing, the danger period is down to “only” 300 years. On the plus side, the process generates a lot of heat, which you can convert to electricity in the usual way.
Continue reading “Nuclear Waste Remediation By Proton Beam”
