Light painting, or taking a few RGB LEDs, a camera with a long exposure, and turning the world into Tron, has been around for a while. We haven’t seen many people using their household CNC machines for the same effect. [ekaggrat] is the exception. He’s already used a 3D printer to do some light painting, and now he’s doing it in color.
This build is an extension of an earlier project we saw that used a white LED to draw pictures within the build volume of a delta printer. Just like the last time, [ekaggrat] wired LEDs up to a RAMPS board and toggled pins with the M42 command. This build merely triples the complexity of the wiring; the RGB LED is wired to pins 4,5, and 6 of the controller board, and the shutter release button of his camera is wired up to pin 11 with an optoisolator.
The ability to blink out Gcode is one thing, getting his two-year-old daughter to stand still for 3D scanning is another thing entirely. With the data in hand, [ekaggrat] was able to run this model through a script that would generate a light painting of his daughter. You can grab the script for that on GitHub, or check out the video below.
